Bicycle or Aircraft welder needed - TIG or OxA - Ferndale, Michigan
发表于 2021-9-1 23:14:52 | 显示全部楼层 |阅读模式
The title pretty much says it all.  I need a steel bicycle frame repaired.
Reply:Location would helpTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Ferndale, Michigan  ^^^see title
GravelThe difference between theory and practice is that in theory there is no difference.
Reply:ok. flying bicycle maybe?i.u.o.e. # 15queens, ny and sunny fla
Originally Posted by soutthpaw
Doh! Tapatalk cut that part off
Reply:What you have there is a $100 bike on a $20 frame, with machine brazed dropouts. The dropout is split right along the braze, the best repair would be an ugly glob of braze that might work if you can get the area really clean, I'll do it for $100, $65 if you do the cleaning to bright metal 3" back on both sides of the break. Have you noticed the problem yet?SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Originally Posted by Brazin
I'll do it for $100
Reply:Actually postage would be a bit more, I'm in the UK right now.
But yeah, I've been given nicer frames by the local bike shop.Failure could be from a badly installed rear wheal plus continued regular use, or being run over by a bus. Not really a candidate for repair if you can't do it yourself.If it was a hand built museum piece I'd un-braze the stub and other half of the dropout, weld and grind to perfection separately, and re-install. Now your talking at least $250. Plus shipping to the UK, ROFL!
Last edited by Brazin; 08-11-2014 at 12:37 PM.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
GMT+8, 2025-12-19 19:34 , Processed in 0.091946 second(s), 18 queries .
