Welder in ct
发表于 2021-9-1 23:14:51 | 显示全部楼层 |阅读模式
Any welders from ct in new haven country?  I am located in oxford ct and need someone to burn in a piece on a trailer. I dont do structural welds yet. Prbably will take 1 hr if that. Its already in place and tacked up with a tig welder.
Reply:Hey! Another person from CT!But no help here, sorry
"I thank God for all the freedoms we've got in this country, I cherish even the right to burn the flag, but I'll tell you what, we've also got the right to bear arms and if you burn my flag I'll shoot you"-Johnny Cash
Reply:CT here too. But not sure I would be much help. Can you put up a picture of it?Miller Multimatic 255
Reply:If you are willing to travel to Brookfield, a good friend of mine has an iron work shop. He does all MIG.I'm sure he would do what you are looking for.If your interested, PM me and I'll give you the info.kidtigger24
  They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
Reply:Brendon, Sounds like you are looking for someone with a mobile rig to come to the job. Wish I cold help you there bud.T.J.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:It doesnt need to be mobile. Trailers got wheels.
.  Your place is a bit far, i dont  like going on 95. I can keep it in mind. I had a local guy lined up before i put the axe to it. But the typical story of where are you now.Ive got the syncro 250 here with stick setup too. i am  just not comfortable yet welding things that could put lives at danger. Once this gets done im going to buy a 252 and give er hell.
Reply:if you want to MIG it, I can load up my 190 and a bottle of c25 and bring that over.Miller Multimatic 255
Reply:BrendonYou are selling yourself shortI have seen some of your welds you are more than qualified to do this. Spend a couple hours practice on some quarter inch steel / stick weld with the syncro / DCYou will be fine.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Brendon You can TIG it too. Just make sure clean bright metal, no mill scale.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Thanks john. Its just one of those things i cant see past. Too big of a risk i wouldnt sleep easy at night. Do you mig tj?  Are you busy?  Could you do it while i waited?  I left another messag with the guy today. If he doesnt call back by the weekend it needs to get done otherwise.
Reply:Brendon.  Sorry getting back to you so late. I just saw this. I do mig. This weekend i am tied up though. Next is open eight now.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
GMT+8, 2025-12-19 19:21 , Processed in 0.091916 second(s), 18 queries .
