FS Hobart Spool Gun DP 3545-20 $500
发表于 2021-9-1 23:14:45 | 显示全部楼层 |阅读模式
Unusable gift as I do not have the Iron Man 230 anymore .   Gun is new , all components it came with still in packaging .    Shipping can be determined based on zip code,  box is  15.5x15.5x3in,  10lbs .     200 A at 60-Percent Duty CycleEnclosed wire spool compartment with Internal spool hub tension adjustment for 4-Inch rolls of wireIncludes contact tips and feed rolls for .030-.035-Inch aluminum, steel and stainless wiresApplications: Aluminum Fabrication,Trailer Fabrication, Sign Manufacturing, Auto and Marine Repair*for the Hobart Iron Man 230 welder*Gets great reviews on Amazon , retail 600 plus after taxesMsg for more info or purchase,  thanks,  would be sent from Montello WI
GMT+8, 2025-12-19 20:43 , Processed in 0.070097 second(s), 18 queries .
