Maxstar 150 or CST280 For learning how to DC TIG
发表于 2021-9-1 23:14:44 | 显示全部楼层 |阅读模式
Hello I am a machinist by trade but I do enjoy welding.  I just wish I had enough spare time to devote to getting good at it... I have a Hobart Handler 140, Miller Maxstar 150 1st gen, Just picked up a CST280 in rough shape but working. Smith Oxy-Acet regulators and torches.  Which of my 2 Millers would be better to learn how to DC TIG with? I have a "K" cylinder of argon but no foot controls so I will buy one for the welder that I will learn on.  Id greatly appreciate your opinions on which will be better to learn on!Thanks,Dan
Reply:i got both.    i dont plumb the gas through the 150 or use its timed selenoid.    the 280 dont have the option.     i like everything manual/external.      it seldomly dont make much diff which i use, cuz most dc tig i do is under a 100 amps anyway
Reply:which maxstar? The S will not tig.
Reply:It is the original 150 with the metal wrapper.
Sent from my SM-G970U using Tapatalk
Reply:Ahh,  forgot about those.  Little tanks
Reply:Whichever one you like better... Ideally one with a gas solenoid.You'll run out of amperage on thicker steel with the 150, so IMO the 280 would be better, but depends what you're wanting to do...Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:If that is your 150 setup ,  then just start tig welding.  You really do not need a amp control for steel. Also, you may prefer a control at the torch and never use the purchased foot control.
GMT+8, 2025-12-19 20:42 , Processed in 0.068832 second(s), 18 queries .
