Well, I'm usually pretty lucky on used stuff - but this one made it 75 feet and the right side locked up...Everything worked perfect on inspection. Rats.First excavator so this will be a learning curve.
About 60 feet from the trailer and the right side was not giving any power but track was still turning, 15 feet later and it locked.2005 model, I've included a video of the issue. Right side is lifted off the ground in the video.The hydraulic motor seems to turn and provide power both directions?To me it feels like the planetary gear set has something stuck, or the front idler bearing has failed?Didn't have time to do anything except look for a rock lodged in the tracks, then I had to leave - back to it on Thursday with the game plan of removing the track and starting there.Any and all suggestions are appreciated
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:The hard stop with the clunk noise has me thinking planetary issue. Pull a plug and do a little magnet fishing.
Reply:Sorry I'm of no help, but I enjoyed your 55 gallon drum video. It reminded me of photonicinduction's coconut video...
Reply:Hard to tell from the video... but it looks like the track stops before the sprocket... so While the clunking and stuff does sort of point towards a planetary issue I would actually loosen the track and see if the idler isn't stuck(shot) or maybe there's a rock lodged in there stalling it.
Reply:I just recently had a rock lodged between the idler and the bracket on my Cat 931B causing the track to stop when in reverse. I saw some gouging on the idler and closer inspection revealed the rock in-between the idler brackets and couldn't be seen. Had to reach in to feel it. Got lucky that after several attempts back and forth with the track lifted, part of the rock sheared off and I could get it out. If you can loosen the track enough to lift it off the sprocket could see if the sprocket turns properly on its own. Could check the idler as well.Last edited by Welder Dave; 10-14-2020 at 03:32 AM.
Reply:Update: no stuck rock unfortunately.Opened the drains to check the oil condition in the final drive...nope... condition: missing.
I flushed it out with diesel, then spun it with diesel in it, drained and repeated several times. Then used rear end oil to fill, spin and drain several times.It functions, is noisy and clunks some, but doesn't get stuck.The floating seal between the hydraulic side and gear side is completely out, the oil pours out of it.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Lowest quote for replacing the seal is $900 + parts.One place said 17 hrs labor or wants $9500 for a new one.Online orders are looking like $2,000.Tough to shop local this way.
Reply:Holy cow! Previous owner was playing "Swamp Monster" with a bad seal in some pretty soupy mud. (Ask me how I know...) I really doubt that just a seal will cure that, My guess is all the needle bearings and planet pins are already gone, and the rest is following. A good used unit complete would be my choice for a part time machine. And I would be suspect of the motor seal too, it might be next, silt seems to get into everything.
Reply:Somebody got rid of that machine just in the nick of time, wonder what the other side looks like inside.
Reply:If you're mechanically inclined you could probably rebuild it yourself for just the cost of the internal parts. I've done a couple of them in the past, but I'm not sure if they were quite as bad as that one...
Reply:Man that sucks. If you swap this one out you can dig into it and see what it looks like. I would look at the other side to be safeMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:I used the machine several hours today - just put oil in the drive and went to work with it.Nice digger
New drive gets here Wednesday from Texas final drives.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:You might want to check the swing motor gear box also.... I don't know if that one is oil bath or not.... but just to make sure it has oil would be a good thing
Reply:With the guy offering that you feel a little better about not getting screwed. He could have told you to take a hikeMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:People get old. People park a machine outdoors, five years later they feel it is good as it was when parked. Charlie Abbott was such a man. He ran a two man excavation company 60 years. At some point he lost his one employee, never hired another. A man in his seventies, he fussed around on some jobs that weren't big, enlisting his wife for shuttle duty.He never said, but I'd guess he failed a CDL physical.The machines got old sitting around. He couldn't bring himself to part with anything. Machines didn't move for at least ten years.Since Charlie's death, his brother made his widow a package deal offer, trucked dozens of machines from CT to VT. One by one Charlie's nephew has repaired to function, if not reliable condition, & sold them. They have a IH 175 crawler loader offered now. Tracks were new 20 years ago, only a few hours on them, but most pins are seized.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Originally Posted by Willie B
People get old. People park a machine outdoors, five years later they feel it is good as it was when parked.Looks like you're getting some great use out of it already!!! squirt some grease in the final one of these times too...
Originally Posted by MinnesotaDave
Likely what happened here as well.Oh well, I've been using it while I wait on the new final drive (just put oil in this drive and let it leak out).This was a huge broken down corral filled with rocks, boulders, garbage, oil jugs, metal, various "farm debris" and aluminum cans...and 7' tall weeds.Now flat and empty
Used the mini excavator to rake up all the crap into piles and dig out the rock/junk/boulder pile.Bobcat got rid of it all.The corral behind it is next, then keep prepping the property for sale. Sweetie is prepping/repairing the house, I've got the outside, shop and outbuildings.
Cenex 365 lube is excellent for a application like this, semi solid at rest and liquifies under movement. It's what all the irrigation guys here used in leaky circle machine gearboxes. Kinda like the old style Cat roller lubes.
Reply:Grade 00 grease or JD corn head grease are other options probably similar to Cenex 365. Stays put when still but flows when parts are moving. Used in leaking gearboxes. I put 00 grease in a leaking bottom roller on my Cat.
Reply:Farm oil makes a fluid gear grease as well. Grade 0 I believe comes in a pint or quart squirt bottle.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Correct. My take on him when I bought it was he is an honest guy just trying to make a few bucks on equipment he bought from his boss.He has proven that with his response and concern for the machine not being "ready to dig" as he assured me.
Heck!!! A tube of that stuff and he won't need a new final or seals for the old one
John Deere also markets "Corn Head Grease" Used it in a rototiller gearbox after a rebuild. Rebuilds are very costly
Reply:Corn Head grease. Learned something new today
.....thixotropic....totally sounds made up
Probably the only good idea you'll ever first hear it from me.
Originally Posted by bead-boy
I'm afraid you came in 2nd in the "corn head grease race". See post #31 from Welder Dave.
Damn! only race I ever thought I won. Oh well!
Originally Posted by davec
You are more familiar with thixotropic materials than you realize. Latex paint. The fact that you can use a brush to apply and it then stays put. The brush applies shear that reduces the viscosity so it flows out, but then you stop brushing, so no more shear and it thickens up and stays put. Lots of things like this in the world but the best things are the ones engineered to do it for a specific purpose like paint and that grease, for example.
Reply:Wow what a way to derail a thread, first we are fixing a mini excavator, now we are watching paint dry! LOLMike
Reply:No applause, just throw money. Have heard that you need to make sure the corn head grease is compatible with the existing gear lube/oil or clean everything up and just use the corn head grease by itself. I used the grade 00 grease because I wasn't sure what was used in the track roller originally.
Originally Posted by William McCormick
How is the price of property out there Dave? And do you have city water or wells?Sincerely, William McCormick
Reply:Had some time to clear out some more stupid boulders, rocks, corral boards/posts, etc.. Even got the tin that a tornado dumped on that shed out of the way
Property prices are fairly low in that area. About the same as the Bemidji area where I sold my place with 20 acres, garage and shop 1500 sq.ft. remodeled home, $220kHers is a doublewide, shop, about 12 acres, $150k (maybe a little less) when we sell.Both places on well water.The new place we bought is in a higher market. Only 5 acres, garages and shop, normal house still in the 1980's in need of remodel, $300k.Also well water.
Thank you for the reply Dave!You have to do the pressure storage tank and chlorine treatment thing with the chlorine chemical pump?Sincerely, William McCormick |
