Estimating & project management software?
发表于 2021-9-1 23:14:35 | 显示全部楼层 |阅读模式
Hey folks, I thought I'd post here so see what welding specific software the pro's here are running for those of you in the fabrication business. I'm an Estimator/Project Manager for a custom welding & fabrication shop and the juggling between the two is getting out of hand. I'm in a situation where I need to be putting in FT hours towards both things (estimating & managing) and, well we all know there needs to be eat and sleep included in a 24 hour day.I'm looking to expand more into light structural & misc metals but most of whet I'm seeing out there caters to the larger industries. I use excel spreadsheets but would like something more plug and play, even a pick and click system as long as it isn't so cumbersome that it consumes even more time for minor returns. In short, I'm hoping there is a system or program that can reduce both my estimating and costing/tracking time so I can focus on other important mattersThanks in advance
Reply:Custom welding and fabrication is a very broad field which is why not many companies want to do it. This is why I love being in this field because most people can't handle it. I bid jobs from $100 to $100,000 all done on separate pieces of paper since every jobs is completely different from anything I have done prior. I have made over 150 stainless conveyors and only 5 were the same.Sent from my 2PS64 using Tapatalk
Originally Posted by K6090
Hey folks, I thought I'd post here so see what welding specific software the pros here are running for those of you in the fabrication business. I'm an Estimator/Project Manager for a custom welding & fabrication shop, and the juggling between the two is getting out of hand. I'm in a situation where I need to be putting in FT hours towards both things (estimating & managing) and, well we all know there needs to be eat and sleep included in a 24 hour day.I'm looking to expand more into light structural & misc metals but most of whet I'm seeing out there caters to the larger industries. I use excel spreadsheets but would like something more plug and play, even a pick and click system as long as it isn't so cumbersome that it consumes even more time for minor returns. In short, I'm hoping there is a system or program that can reduce both my estimating and costing/tracking time so I can focus on other important mattersThanks in advance
Reply:I made a chart how long took to make 1" weld up to 40foot weld. This also cutting steel , drilling both hand and drill press, machining and painting It took time for chart it included down time from employ aka Goff off timeBe for had chart double the cost of steel, bolts and any all other cost be for laborThis work ok at start sometime it most it was low and rarely high.At times I would a have pain the but charge Dave
GMT+8, 2025-12-19 22:11 , Processed in 0.071651 second(s), 18 queries .
