Airco: Trying to set up Airco CV-450 and Miget Spool Gun on a rotary phase converter
发表于 2021-9-1 23:14:30 | 显示全部楼层 |阅读模式
Any old-hats out there who can help me set-up this old Airco CV-450 and Miget Spool Gun?  Was used in an aluminum boat factory (SeaArk).  The spool gun is connected to an ESAB AHC-M/S control.  It all came to me this way.  There's a relay hanging beneath the control, just for fun.  (I have pictured a second Profax control that I have available, but is not part of this setup.)  I also need manuals for the welder, control, and spool gun.  I'm trying to run all of this on a phase converter.  Wire started feeding, but stopped after a few inches.  I have unequal voltages between phases of my very old Kay 7.5 hp rotary phase converter.  Yes, the T3 manufactured leg is on L3 of the welder.  But I'm wondering if somehow the screwed-up voltages from the phase converter burned-up my spool gun feed motor....because the feed motor runs off the arc voltage?????AIRCO CV-450Code 0627Serial RH101072Stock 1346-7017
Reply:Posted a response but it has disappeared. AEC 200 Profax is the same as the Miget spool gun. Did you post in more than 1 forum? That just messes everything up. Welder appears to be made by Miller. https://uploads.tapatalk-cdn.com/file...ontrollers.pdfLast edited by Welder Dave; 03-20-2021 at 06:30 PM.
Reply:I did.  Sorry.  Posted looking for manuals in another forum.  Looking for electrical advice with phase converter here.
GMT+8, 2025-12-19 20:48 , Processed in 0.097298 second(s), 18 queries .
