220v socket size???
发表于 2021-9-1 23:14:30 | 显示全部楼层 |阅读模式
My grandson bought a big 220v heat treat oven. I looked at the plug and it looked just like a 110v 20a plug. An electrician ran a 220 line to it and used a compatable socket with that 110 looking plug. Is that right? I thought 220 plugs and sockets look like what you have on your dryer.
Reply:It's probably a nema 6/50. Common on welders and such. Dryer plugs are only good for 30 ampsMiller Multimatic 255
Reply:Here is a handy chart of a "few" of the plugs and receptacles.https://www.stayonline.com/product-r...ence-chart.asp
Reply:It looks like 120 but blades are as shown which are different and 240 dedicated. The 2 flats is one and the one sideways one type is opposite side rotated from 120 style configuration.Most like that are only 20 amps though. When you step up to 30 amp then they become that larger size your thinking about on dryer at 30 amp or range at 50 amp.The smaller 30 amps you used to see but not so much anymore. They use to use on water heaters back in the day. Sideways or angled but not big like a 30 amp dryer.Last edited by danielplace; 04-01-2021 at 10:37 PM.
Reply:It os all a matter of the amps required. The second number in the plug model number is amps, so a NEMA. 6-20 is a 20 amp circuit.
Reply:Just for giggles and grins I looked up a couple of heat treat ovens. The plugs are all over the place, even within the same manufacturer, depending on current draw. One manufacturer is using NEMA 6-15, 6-20, 6-30, and 6-50 all on the same product line, depending on oven size. That's crazy. You would think for cost savings they would just settle on one or two.Miller Multimatic 255
Reply:For welders I think the Tombstone style 200/225 amp transformer stick welders that were so prevalent years ago set the pace at 50 amps.With the typical welder outlet style we still know and use today is still same configuration 50 amp they put on the transformers for years.
Reply:Well, without looking at his specs I would guess then that it has a 20 amp draw. Maybe I'll look when I'm over there again.
Reply:Something you know is going to be drawing right up near 20 amp continuous load might be worth pulling #10's unless run is short.
Reply:Sounds like a 240 volt 20 amp it looks close to a 120 volt 20 amp.Dave
GMT+8, 2025-12-19 20:44 , Processed in 0.071834 second(s), 18 queries .
