😧——what the heck???😧
发表于 2021-9-1 23:14:30 | 显示全部楼层 |阅读模式
Well we’ve been here for 35 + years now and had “ That Call” no business owner ever wants to hear “ there’s Smoke coming out your shop!” When I made it there the fire department was as well and when the smoke cleared this is the panel . Now of course we’ve got insurance and pay enough taxes that all  business's do to stay legal. I’m  just looking for a answer to why or how this happened  and what’s the correct way to get my shop back in forward motion .
thank you for any help with this matter as I feel that I’ll get some answers from reliable sources on this forum. Also Have a Happy Easter and enjoy it with family and friends! .
Reply:Is this a joke. At first I thought the pipes all melted and left the wires but looks like there was just wires or what. The PVC would have made a melted mess or locknuts would still be there. What are 2 big 2" holes in back of panel wide open. Man to me sorry to say it looks like it was long overdo for what happened. Maybe I am way off base.In any case you need a licensed qualified electrician come and rip everything out in it's entirety and start over.
Reply:I’m  just looking for a answer to why or how this happened  and what’s the correct way to get my shop back in forward motion.
Reply:Rodents?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:It looks like a shotty installation. There's no connectors or conduit except for a couple on the bottom with a piece of conduit that looks like it was cut off with the wires still in it. It really bothers me that the feeder had no protection.That may not have been the cause, but it's a good indicator that there were shortcuts taken elsewhere that may have contributed. Unfortunately, we went through the same thing when my parents shop burned down. I feel your pain; a fire is a bad thing to go through. Hopefully the damage wasn't too bad. The first step is to call the insurance company and follow their instructions. They will likely send their own investigator to try to determine the cause.When they finish their investigation you can begin the clean up and rebuild. Don't touch anything until they give you permission. They will probably ask for a list of everything damaged or lost with values.I would also start getting estimates for repairs so that you have something to back you up if there's a dispute with their assessment. You likely won't get any payment for any work you do yourself. We didn't get full payment for the cleanup because we did it ourselves. I think they paid some for the dumpsters, but none for our labor. At the time we couldn't find anyone local to do the cleanup, so we had to do it.ZachLast edited by WTXBTUMOVER; 04-04-2021 at 02:40 PM.
Reply:I've seen plenty of meltdowns like that as a result of a continuous heavy load overheating a breaker to the point where it started burning the plastic and just took off from there. I am in the desert and every one I ever saw was an AC unit breaker that started it due to AC never shutting down for hours if not days,. AC is not considered to be a continuous load by code due to cycling but here in the desert is can easily become one. Is there a chance something like a compressor or other heavy load was running non-stop? It would take a load to generate that kind of heat, and possibly a loose connection. The ones I've seen have almost always been ITE-Siemans plug on style and I am surprised to see it in your panel which is a top of the line Square D QO.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Having always done my own electrical work, that's a scary picture....The thing that stands out to me is the unprotected feeders coming thru that ragged hole. I assume that, if there were some now burnt-away PVC conduit, then there would have been a tin nut left inside. I don't understand the comment about the missing 2" knockouts though, we don't live in a perfect world, how would that have been a contributing factor?As much as overheating breakers, I've seen the buss bar connection, often at the main breaker push on connection, corrode and start to burn.It Amazes me that the fire investigators are able to determine the exact source with something like that!
Reply:Is that Vinyl Siding? Was this on the Outside of the building???
Reply:Looks like there were enough code violations to have started that fire years ago. I’d say you were lucky for a long time. Now to fix it simply hire a licensed,  bonded, insured, electrician and give him a check for a couple grand to get it squared away.
Reply:All of this "code violations", "licensed sparky", etc are fine.  It doesn't address any of the faults present in the wiring that are so out of whack, that the building shoulda burnt down years ago.  WHAT ARE THE VIOLATIONS???????????Don't just say it's crap, say why it's crap.
Reply:Is that a 208V 3 phase feed with single phase breakers?
If the heat is enough to melt the plastic on the breaker, wouldn't it have generated enough heat to trip the breaker?  My understanding is that you have two components to a standard breaker..................thermal overload, and magnetic trip for shorts.
No pipes on any of the wiring. 2" knockouts wide open. The main is loose wire no pipe. It is not even good if it was temporary. That should have never been powered up.
That is my understanding as well however I have seen this more times than I can count. It is possible that the thermal trip requires a hotter temperature than it takes to burn the plastic.
Reply:You can be 95% certain that a loose connection along with possibly the wrong over current but not necessarily. When things get loose things start to get hot but the breaker does not know or see that and continues to cook until something gets hot enough to ignite itself or something in contact with the wiring. A loose connection on a traditional breaker will not usually cause it to trip and even 15/20 amps on loose connection can create plenty of heat without drawing more than the breakers rating. These aren't shorts to ground remember.It thinks it is normal load. None or most of this looks like it was not in proper piping. Panel cover may have not been on. The feeders exposed. When you see that you just know it is all a mess.
Reply:Anyone see the feed coming through the wall, looks like it has been rubbing on the cut away tin. That is really bad. Looks like a lot of the hot wires on the right side have been pulled tight and all ran through the 1 unsupported hole on the bottom left.I know I dont always do things exactly proper, but I have always feared losing 500k in machinery to a $3 connector. I normally run electricians out because I want oversized wires and such and they dont understand why I want things done right. Sent from my SM-G960U using TapatalkLast edited by Country Metals; 04-06-2021 at 08:17 PM.
Reply:When you reorient the pic like that, I am starting to think that the fire didn't start inside the panel. More pics would help, but fire spreads up and out much more than it spreads down. That fire started outside the panel to the right where to coke bottle opener is situated on the wall. I am not saying there's not a million code violations, but my money says something else started that fire.Miller Multimatic 255
Reply:Thanks for y’all’s opinions on what information I had . This is inside a shop that’s been working 35+ years with that panel. Now NOTHING was on except WiFi and a security camera. Oh and phone. We’ve heard everything from what you’ve been replying as well. Even by certified electricians as they chuckled and looked back over the mom and pop shop and said but it’s been working out this long just if you  get any more workers and welding machines you’ll need a new bigger panel. It was even moved by the electric company! And turned back on .! As for the wise cracks I new they would happen, that’s just people mad at themselves for their own personal choices. Those remarks really show it too  but Anyways ... And as the security cameras shows me checking machines and tanks and out the door I went out the door as the cowbell rang.—-Reason being ,because when firemen and I arrived the only electric door was wide open and the fire marshal definitely wanted to know that .Now then, the  electric company came out and said that the transformer went back to box with 45,000 volts and it welded the 200 amp breaker then back to transformer and blew two fuses at pole. I seen them put em up when they cut loose from building. Yeah the panel  was way outta code violations even for a 3rd world country standards we all can see. And the new will have everything 2021 code approved. I’m just checking azzholes before the discussion with insurance company is why I came here. All my old timers have passed.. Oh as for the security cameras last pic before going offline as it says is a white light about 8’ off the ground aprox at meter disconnect, outside it’s even that high .. Like 5-5.5 feet somewhere is code I THINK. Not 8’ I’ve got other pics if anyone is somewhat respectfully curious that might have some insight about any of this. I’ll weed through the remarks to find those ones that use this forum for helping and problem solving. Thanks for your response . Sorry I didn’t get to finish with this last night but interesting thing happened today while at burnt shop, the electric company came out to a power outage here,.... I said well yeah I’m the last on this leg but they said naw fuse is blown,? I said nothing is on it and they changed em Monday. But one was gone they blamed a bird squirrel, ape, etc, got in it . I said strange, 35+ years and never had blown and blowers again? Well then I get my phone out to record these hardheaded linemen. Well one was , and as he’s using a yellow pole the young guy says “ Bill stop and look, ain’t that oil coming out , naw I’m gunna hit it anyways “ mind you I’m right there when he has it looped on top and says well I’m gunna Tap it....���� kaboom . And they get in there truck and leave . also sorry for the sideways pics , but ANY INFORMATION would help as I’m just wanting to get the correct answers  and of course the blame. Then  eventually  weld stuff up and keep my little town happy with their metal and aluminum items  or floating as always. God bless our Veterans and troops ! -thank you valweld .P.s. the panel inside was on but  machine screws were wobbly, so I assumed it blew off during the electric issue.
Reply:I think what you’re going to find is that people don’t believe your story. There is no way on God’s green earth that line took 45,000 volts. Where, pray tell, would that have been fed from? In my experience, an electrical utility admitting responsibility for anything is hard to find. Now, I would believe that you used up your luck with that panel, shorted your feed to ground and blew the fuses at the pole. You’re not going to convince anyone that the panel was just fine and it must have been the utility.Anyway, your insurance investigation is going to tell the tale.Oh, and I don’t believe your electric utility moved that panel, either. Took one look and pulled your meter, I’d believe.
Reply:In light of these new facts it sounds like you may have had a short in the line conductors on or in your building which caused a massive amount of amperage to flow causing a fireball inside the panel before the transformer mains blew. We had one where a roofing truck backed into the main and it went line to line, the amount of damage in just the short time before the mains opened was unbelievable.Then again if the mains fuse blew again when you were disconnected (which it looks like that's what you are saying) I don't know, are you the only one on that transformer? Is your service drop damaged, what about your meter base? Have they clipped your service drop at the transformer?Last edited by bigb; 04-07-2021 at 06:46 PM.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
GMT+8, 2025-12-19 20:45 , Processed in 0.098301 second(s), 18 queries .
