I have been welding with this machine for a few weeks with no problems. Then all of a sudden it quit welding. It ran a grinder but wont strike an arc. It would idle up and still wouldnt strike an arc. Now it wont idle up when I go to strike an arc. I can manually idle it up and it will weld, just wondering if anyone had any ideas? Your help is appreciated!!
Reply:Whats funny is I have proper amperage at the positive/negative lugs. My ground? Bad connection at stinger? Any ideas?
Reply:Just checked the positive/negative lugs again, now its showing an open circuit. My welder is going berserk.
Reply:Could be failed main shunt coils or bad contacts on the coarse amperage selector switch or a broke copper strap to the coarse amperage selector switch or . . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base! |
