Sm1 and wc-1 to mm200
发表于 2021-9-1 23:14:29 | 显示全部楼层 |阅读模式
Ok I have a mm200 with the 14 pin plug I also have a wc1 and spoolmatic 1. My question is how Hook them all together to work properly?
Reply:The manual is kinda vague on how to install the wc-1 to power source. Do I use the 14 pin plug on the mm200 and use 115 volt ac from the Wall ? And I also don't have any of the cables for the wc-1
Reply:The serial number on the wc-1 is jh230958It has a 3 prong Hubbell plug on the back and a 2 prong female Hart lock plug.
Reply:Download the later WC-1 manual o1210j and install a 14-pin plug on the control cables of your earlier WC-1 to match the arrangement shown in the later wiring schematic.  You will only need 4 of the 5 conductors of the earlier version eliminating the one shown going to the wide slot of RC2.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I think the transformer is shot I have power going to it but nothing coming out.
Reply:Duane55 would know what transformer I would need to get as a replacement? I haven't had much luck finding parts for the wc-1.
GMT+8, 2025-12-19 22:07 , Processed in 0.070347 second(s), 18 queries .
