Need to decide between Lincoln 210 Mp and Millermatic 215
发表于 2021-9-1 23:14:21 | 显示全部楼层 |阅读模式
Have you ever made a dumb mistake like selling a welder that you regretted almost immediately? Yup that's me after selling my Lincoln 210. Admittedly I did not use it much after getting into TIG, but now I am interested in buying a, yes, you guessed it, a ~200 amp MIG welder. Not interested in the scratch TIG functionality, not interested in no-name brands, no matter how cheap, etc. but I want:* dual voltage (120/240)* inverter (=light, about 40 or so pounds)* qualityThere used to be an Esab 211 but cannot find it anymore. So ultimately I narrowed down to Miller 215 MP vs Lincoln 210 MP. I am not a brand fanatic so no hard feelz either way. Any practical advice or point I am missing? Thank you in advance.HTP Invertig 221H w/ CK20 water-cooled torch  •  Lincoln PowerMig 210MP  •  Hypertherm PowerMax 45XP  •  Optrel Crystal 2.0
Reply:I personally like the color display on the 210 Lincoln. I’ve had one since they first came out and had no issues  I’m sure the Miller is ok, I like red paint better. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:If you're open to using a step-up transformer for about $100, you don't have to limit yourself to machines that are DV by default, which will open up other options.  An HTP MTS 210 would complement your 221 nicely.  $1600 before the pricing goes up on July 15th.  Just saying.
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:So you do want/need the tig functionality too ? You said no scratch start but does that mean no tig really needed at all ? Lots more machines to look at if you are only needing a Mig.
Reply:If you already own a nice TIG, and aren't interested in the scratch-start TIG function, why spend more money on multiprocess machines?Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:The larger is better.It give power for later work.Note 240volt is best way to go. The 120 volt is just flipping the breaker.Dave
Reply:have you looked at the millermatic211 ? i picked one up couple months ago and like it for the type of stuff i do around the house. although a havent used it a hek of alot yet since i been stick welding lately. the only thing is it doesnt have digital readout but you didnt mention if thats a necessityinvertig 221 water cooledmillermatic 211hypertherm powermax 30xp
Reply:A Miller 211 is pretty much the mig only version of the 215.
Exactly. My problem is none of the majors offer a 200-210 amps dual voltage inverter MIG-only machine, or I haven’t found any. Frankly i think adding on scratch TIG is marketing BS.
It’s out of stock sadly
Sent from my iPhone using Tapatalk Pro
Reply:Between the two I would pick the Lincoln. It has more features/settings you can use and tweak, such as inductance, burn back, etc. I was quite surprised to see that these either don't exist on the Miller or are not adjustable.
Reply:So i went and got a Lincoln 210. My LWS did not have any in stock but Praxair did, so that’s where I bought it. I think I won’t regret it, having used it in the past. Thank you all for your input. Sent from my iPhone using Tapatalk ProHTP Invertig 221H w/ CK20 water-cooled torch  •  Lincoln PowerMig 210MP  •  Hypertherm PowerMax 45XP  •  Optrel Crystal 2.0
Reply:I think you meant to say Miller Multimatic 215 not Millermatic 215. I think you made a good choice with the Lincoln. Esab has the Rebel series that also get good reviews. When Miller came out with the Multimatic 200 I thought they were over priced for what they were. They got decent reviews but just seemed too high a price and the 215's were more expensive. The Esab and Lincoln 215 machines came out with more features and a lower price to compete with the Miller. I suspect that's why Miller added the 215.
Reply:The Multimatic 215 is DC. The Multimatic 220 AC/DC is AC and DC.
Ok here it is, took its place next to its siblings. Sent from my iPhone using Tapatalk Pro
Reply:Nice set up ! I like that everything is on one cart, great for saving space (because there's never enough). Thanks for sharing. I dont think there was any wrong decision, I have welders of many different manufacturers, but I have been really happy with my 210 mp that I've had for six years. I have mig welded aluminum , stainless, mild steel solid wires, gasless fluxcore, gas shielded flux core, mig brazed, tig brazed, tig welded  stainless, mild steel, 7018,7014,6011,6013,308,309 welding rods. It runs mig off 120v really well, stick not so much maybe 75 amps,depending on wiring. I have no regrets about buying the lincoln 210 mp, it has, and still does everything well except for 6010 which if you turn up the arc force and hot start, you can kind of run it , but it sticks alot. I hope yours works as well as mine.Best RegardsAirco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
GMT+8, 2025-12-19 22:05 , Processed in 0.086670 second(s), 18 queries .
