I have a couple of heavy-duty racks that I use to store steel. One of the racks sticks through a hole in the wall which limits the maximum height of the rack. I decided to cut off the unusable top of the rack and use it to extend the height of a second rack, located in my addition, where there is more head room. 1. Old rack
After cutting off the four corner columns, I ground off the cross brace. The original cross brace was 18 inches long and the new one needed to be 24 long. Also, the new brace needed to have a higher section because I wanted to rest some metal directly on the cross brace.2. Grinding off cross brace
I selected a 1/16 wall 1-1/2 square tube for the new cross brace. I used my Fireball angles and magnetic blocks to fixture the frame in place. I find the Fireball tools to be very useful.3. Fixturing with Fireball Tools
The next step was to tack weld the cross brace in place. I tack welded all four sides of each tube before I welded it out. I used my Lincoln LE31 MP welder which is 140 amp 120 volt multi-process welder. I used .030 wire, which was in the welder, but I should have switched to .025 wire, because the thickness of the columns was only about .035 (Not including the paint). 4. Tack welds
Next, I welded it the frame. I positioned the frame so that the heavier 1/16 wall tube was on the top, to help prevent burning through the thinner metal of the columns on the bottom.5. Weld-1
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE 31 MP & Lincoln 210 MP
Reply:6. Weld-2
Here are two pictures of the extension frames on top of the existing steel rack.7. Frame-1
8. Frame-2
I blind riveted tabs on the end of the extensions to align the extensions with the existing columns of the steel rack. I was planning on welding the extensions, but it was so rigid that I didnt bother welding them.9. Blind rivet splice
And here it is all done.10. All done
-DonSmith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE 31 MP & Lincoln 210 MP
Reply:Looks good and a great reuse of material.I personally would weld out the splices because the tabs just create a hinge point.But that's just me!
