Made A Stainless Steel Rail With My New JD2 Bender, After I Got Back From The Dentist
发表于 2021-9-1 23:14:12 | 显示全部楼层 |阅读模式
When I got back from the dentist at around 1:00 pm I started bending up a little rail job for a friend. It came out great, the bender seems strong it does chatter a bit on stainless steel, so I put some Beeswax on the pipe before it goes through the follow-bar, and it stops the chatter. I have used so many benders and have so many habits from them that it took me a few bends to feel at home with it. But all and all it works well.  The only other bender I have used that will do this tubing is the Hossfeld extra heavy-duty bender with the hydraulic system. And I am sure there are some high-end benders that will also do it but for under two thousand, those are the choices.
These are the wheels and Step-Locks that I plan to put onto a rolling table for the bender.
Sincerely, William McCormick
If I wasn't so.....crazy, I wouldn't try to act normal, and you would be afraid.
Reply:If you are going to weld stainless steel tubing, you have to preload the pipe that is getting another pipe welded to it. Or it will bend a lot from the weld. I use a little gizmo I made that uses one C-clamp to preload the pipe. After it cools you just take it off and it is perfect. Sincerely, William McCormickIf I wasn't so.....crazy, I wouldn't try to act normal, and you would be afraid.
Reply:Nice.  I put hydraulic on my mod 32 a couple months ago.  I have only bent one test piece.  Have used it manually on a couple of jobs.  I think the the mod3 is a better manual bender than the mod32.
Reply:Those are nice bends.  What is the machine with the huge pulley?
Originally Posted by tapwelder
Nice.  I put hydraulic on my mod 32 a couple of months ago.  I have only bent one test piece.  Have used it manually on a couple of jobs.  I think the mod3 is a better manual bender than the mod32.
Reply:That's nice work
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I have always wanted a bender,, is any of these benders capable of bending 1" diameter solid steel round bar? Everyone talks about tube and pipe,, but, it is hard to find anything about solid round.
Originally Posted by walker
I would be interested in seeing that tool if you get a chance to snap a pic. I have always used different pieces of heavy tube and shims, it never occured to me to build a tool.
Reply:I like your design.  Never considered offsetting the clamp.
Reply:Funny.  I have straightened tons of fencing and railing. With setups in that configuration.  Yet when making a tool to preload tubing, I made it with the clamp in the middle. Symmetry?
Reply:If the  fulcrum is centered, and the end points equidistant from the center, I don't think it matters where the clamp is.  It works applying force to both sides of the pipe on either side of the weld if everything is in equilibrium.
Reply:if the clamp, and the other welded end piece, are the same distance from the center, you're really just forcing the pipe to rotate around the fixture itself.  The fixture is the plane..........and the pipe is the material trying to conform to that plane.
Reply:In other words
  The damn center thingy is pushing against the weld area
Reply:Don't mind me.  I just finished an entire tray of fig newtons, and I got one heckuva sugar high
You eat one, and you can't stop
Reply:his setup is easier to handle and fabricate.  You can also get more leverage by moving the clamp. I am pretty sure i followed a design by Brainfarth. He made a nice one.  So it is his fault,  I built mine with a center clamp.
Originally Posted by farmersammm
If the  fulcrum is centered, and the endpoints equidistant from the center, I don't think it matters where the clamp is.  It works by applying force to both sides of the pipe on either side of the weld if everything is in equilibrium.
Funny.  I have straightened tons of fencing and railing. With setups in that configuration.  Yet when making a tool to preload tubing, I made it with the clamp in the middle. Symmetry?Very nice, I will definitely remember and use that, thanks.
Reply:A mini "Jim Crow" rail bender. Whatever works.https://www.indiamart.com/universal-...chanical-jacks---Meltedmetal
Reply:This is the one I made for the 3/4", 7/8", 1", and 1 1/4" solid bar. I took the right-angle grinder and broke the sharp corner so it would not dig into the stainless pipe and used it, haha. I will make another one just for 1.66" O.D. Pipe.
Reply:The JD Square is one of the nicest around for bending tubes.  Race car guys love them.  Me, I have a Hossfeld with hydraulics, its rough and crude and will bend tube, pipe, square and retangluar tubes, angle iron and flat bar.  dies get expensive...It seemed like a good idea at the time!
Originally Posted by welding1
The JD Square is one of the nicest around for bending tubes.  Racecar guys love them.  Me, I have a Hossfeld with hydraulics, its rough and crude and will bend tube, pipe, square and rectangular tubes, angle iron, and flat bar.  dies get expensive...
Reply:I got my little bending cart made for the JD Squared bender. It came out nice. Very solid, and stable, with or without the step locks engaged.
I used a couple of different Hossfeld benders, I started on a Hockey stick, and then I used two different hydraulic Hossfeld's. They are good to have around. But if you get a Press brake/break, or even a press and a V-block and ram you start not using the Hossfeld as much. I used it to bend an arc into iron handrails and aluminum and brass handrails with plate aluminum-supported Teflon die's I made for it. I miss it. Sincerely, William McCormick
Originally Posted by jw3
Why do you prefer the JD to the Hossfeld?Sent from my iPhone using Tapatalk
Your support/cart is the cat's meow.  Now, if it were only remote-controlled for easy movement around your shop.
Reply:This is what I did with my JD2 model 32 bender--mounted on a custom made frame I built to fit an ancient Kennedy roller cabinet. Installed the electro/hydraulic power pack inside the cabinet, with the motor end just barely poking through for cooling. Bending dies are stored in a rack at the bottom; accessories and related tools in the drawers. Wired it through the cabinet for convenience. Also shown is my first bending project done with it.
Reply:Made a back- breaker tool.  I only cut the hole, everything else was precut drop.  Used on this 107 feet of pipe rail.  Worked well.  I rarely get pipe jobs, this was kinda fun.
Reply:Nice Job, Looks Great !
Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
Reply:Thanks.  And thanks for straightening the photos.
GMT+8, 2025-12-19 20:46 , Processed in 0.095458 second(s), 18 queries .
