1987 Dodge D350 Welding Rig..."War Rig" build.
发表于 2021-9-1 23:14:11 | 显示全部楼层 |阅读模式
Started out with a 1987 D350, 4spd standard with a 360 gasser.
Reply:Picked up this litter welder to run until I get my old Hobart running. It's a 1980 Acklands G225, same as a Miller AEAD200LE, sat inside it's whole life, not used in a decade.  Got her purring like a kitten, welds nice! More to come, need to finish my toolboxes.
Reply:And yes I will be changing the hitch so it's tucked in wayyyyy more.
Reply:Just tuck in the receiver tube and leave the horizontal tube where it is for a handy step.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Truck looks great! Better and better with each picture !Sanrex Sanstick 140s(hotstart&dig set perfectly)Thermal Arc 185( if you've used one u know)Thermal Arc 400 gmsMiller Shopmate 300( best wire arc!)Miller 75dx feederMiller PassportMiller s22p12Everlast 210stl30a
Reply:Makes me want to get my old 78 PowerWagon back on the road again.  400cid, NP 435 transmission, NP 203 transfer case, Dana 60 rear, Dana somethin' front.  Was a workhorse, and a pleasure to drive............just didn't like passing any gas station on the road without a stop-in
(Might be a Dana 40 on the front, cant' rightly remember)
Reply:You're in Saskatchewan so shouldn't be hard to round up some "Genuine Fire Resistant Saskatchewan Seal Skin Bindings" to hold that welder on the deck. Those are decent machines and became the Legend but replaced by the Bobcat models.
Reply:nice looking rig.  that 360 is a brute.  had 5-6 and were fantastic.  worked for chrysler back then in mid 70's.i didn't notice if you posted the dodges milage, if it hasn't been done yet, replace the timing chain with a double roller timing chain.  first check what year dodge went to a steel chain.  previous 318-360 timing chains had plastic coated gears and age and mileage made the plastic teeth break and fall off and chain would slip causing lots of problems.lincoln 125spmonkey wards 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dof course duramax diesel
Reply:Got a flatbed Ford dually in the yard that would do well for something like this.  Always wanted to make it into a shop truck, especially since it's a 5sp manual transmission and full crew cab.  Just gotta win the lottery first!I'll live vicariously through you for the time being.  Can't wait to see what you come up with next!
Reply:Plan is to put my '45 Hobart on it if I can revive her!
Reply:Potential steering wheel for the War Rig, yay...nay?
Reply:NAY! Won't be able to hand over hand when trying to get into tight spots.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGANOhhh my next mission is to get the Hobart revived, and if successful I am thinking I will chop it 6".  Took the wheels off and tossed her on the War Rig for a mock up, Ideally I'll have her sitting another 6" to the rear but had no help to line it up exactly where I want it.
Reply:There's a guy up in Canada that posts on YouTube, or used to.  FieldRes, or something like that.  You guys oughta get together.  Both of you seem to like the old classic machines.  He's probably got the first Lincoln ever built
  Guy used to post funny videos, but stopped, and removed them some time back.
Reply:For those who might be wondering why no updates.Project on hold, squished 2 fingers a work few weeks ago, popped the tips like sausages bursting on the grill, ripped the nails up at the roots, cuts behind the nails to the bone and shattered part of the one finger tip.....so off work for a bit.
Reply:I'd post the pics from 30 minutes after it happened but some people might not appreciate it lol
Reply:You're lucky to still have them, I had a similar smash on the pinky and ring finger tip on my left hand 14 years ago and lost 10mm of the ring finger. The pinky tip still looks a little flattened. And I still have issues in cold weather.
Reply:Yup winter will be fun...boo!  Lol
Reply:I crushed a finger on dump truck tailgate but thankfully it mostly healed. Worked with a guy once who lost a finger and got $17K in compensation for it. It got squished under one of the plungers on a 1/4" x 10' plate shear. That had to hurt!
Reply:I really like the looks of your weld rig, when you get healed up and back to workin keep us posted, take care of them fingers, ive had that happen many times and it hurts like hell...it caused pain in my chest lookin at the xray. Get well soon and be safe
Reply:Heal up good and fast.Road trip buying welders is a nice diversion.
Reply:Ouch! I hope that you recover quickly. Nice build on the truck too.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:I hope those fingers heal well... it sucks not being able to use your hands for manual work for a while.Regarding the truck... do you plan on touching up the suspension of that vehicle? It looks like right now it has zero suspension travel... Stiffer springs or adding new leaves to the current leaf spring packs could be a nice improvement. I know nothing about the suspension setup of that truck.Mikel
Reply:Not much to update. headlights, clearance lights, 2007 F250 rear leather seat install, lifted the deck 2'' and put quad diamond stacks on.
MorganEverlast PowerARC 200STi (2018)My homemade Welder (2011)Lincoln SA200 (1978)Lincoln SA200 (1974)CANOX Big Red 300 (1974)Homemade (early 60's)Hobart Hillbilly 300 (early 50's)Homemade  (early 50's)Hobart G-200 (1945)
Reply:These things keep following me home!
Reply:Lookin good... you in the Weyburn area?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I like seeing bed from truck.A stick is great .Very few today can drive stick today . My son can drive stick and first car stick no want to drive his car. If someone ask to use the he held up the keys and said it stick. No one ever use his car.Dave
Reply:decent trucks with a stick shift are hard to find around here, I shopped around for 6 months and found one but the only thing that was any good on the truck was probly one lug nut. So i had to sewttle for an automatic, still learnin how to drive an automatic on these mountains with a 15000 pd truck 5 years laterSo how is the fingers doin? And did you you get that old hobart workin? Looks like some nice pipeliners you picked up though
Reply:Tossed the Miller Killer on the War Rig
Reply:MorganEverlast PowerARC 200STi (2018)My homemade Welder (2011)Lincoln SA200 (1978)Lincoln SA200 (1974)CANOX Big Red 300 (1974)Homemade (early 60's)Hobart Hillbilly 300 (early 50's)Homemade  (early 50's)Hobart G-200 (1945)
GMT+8, 2025-12-19 20:46 , Processed in 0.071167 second(s), 18 queries .
