4 x 6 bandsaw bearing question
发表于 2021-9-1 23:14:08 | 显示全部楼层 |阅读模式
I replaced all mine in 2018 with VXB 6000ZZ 10x26x8 shielded bearings. I haven't used the saw daily but they only lasted a little over 2 years. They don't grind but you can barely turn them with your fingers when all pressure is off.Since they're shielded can they be cleaned and re-greased somehow? And the shield replaced without damage? Or maybe drip some 3-in-1 oil into them instead? I have to replace or clean all 6.But there are a number of 6000-2RS or 6000RS sealed bearings on Amazon for pretty good prices. Maybe that's the better way to go?
Reply:Are they rubbing the holder? If shielded, then it is tough to believe anything infiltrated them especially with infrequent use.  Humidity?  You run some stickey blade lube?First,  make sure they are worth trying to save.  Are the square, no wobble?  If, yes the toss them.  Because the blade wont be able to cut straight.Otherwise,  I would try to lube them. Soak, 'em like a bike chain. 'Cause 2 years is not much, given infrequentuse.
Reply:I replaced mine with the cheap ones off eBay. That was 7 years ago. Still running fine and the saw cuts straight. Use mine every week, not daily.ChrisAuction Addict
Reply:I use a hard waxy blade lube stick from Olson. Square and no wobble. They're just really, really tight. I guess it's too much trouble to pull the shield off, soak and relube then try to get the shield back on without messing it up. I'll just switch vendors since VXB's bearings didn't last too long. Plenty of options on Amazon and since we have Prime I can get them pretty quick.
Reply:I would suggest to just replace them. They are cheap enough.I bought a used Makita Portaband and noticed that some of the bearings where shot. I just bought a bunch online and replace them all.Mikel
Reply:I've had good luck with Fluid Film lube. It penetrates and lubes. I used it to restore the bearings in the fan motor in my round top welder last year. One of the bearings was seized. After the fluid film application it loosened up and flushed out old dry lube. You may give it a shot - its cheap and it might save you the hassle of new bearings. Post 15 has the results of the fluid film, if you want to see more on the motor tear down its in post 13:https://weldingweb.com/vbb/threads/7...85#post8760085
GMT+8, 2025-12-19 22:08 , Processed in 0.068769 second(s), 18 queries .
