Transformer repair
发表于 2021-9-1 23:14:07 | 显示全部楼层 |阅读模式
I’ve got a miller thunderbolt that needs the transformer lead spliced .  Thought I’d ask someone who maybe had a better idea and  the best way to splice it together again. Thanx !!!
Reply:post some pictures of what you have to work with..
Reply:Thanx Dave,  Appreciate your reply.  Should be a pretty easy fix
Reply:Your welcome
Originally Posted by smithdoor
Most modern welds today have aluminum. I would use splice in copper wire. Using Split Bolt Connector for Copper and aluminum and Anti-Oxidant Compound.I have found this works best for high amperage. Davehttps://www.lowes.com/pd/Gardner-Ben...mpound/4514334https://www.lightingsupply.com/penn-...20group%20%231
Originally Posted by Hobbytime
take some fine emery and clean up about an inch on both sides of the crack, if its copper I would braze it back and be done, if its copper coated aluminum I would find a mechanical means to fasten them back together..
Thanx hobbytime ,  ya it’s aluminum taking it out to get at it better my all thumbs hand slipped and broke the fan blade.
JB weld back together, If that doesn’t hold I guess a new one is only about 15 dollars.
Reply:una pregunta le ha pasado a alguno de ustedes que al encender una Thunderbolt 225 XL no tenga salida ninguno de los 2 transformadores secundario? ni el bajo ni el alto. Que podria ser? la probé con otro eje selector de otra maquina y tampoco genera la salida de 70 voltios.. Que podrá ser eso?
Originally Posted by MinnesotaDave
I put that through an online translator:
GMT+8, 2025-12-19 20:45 , Processed in 0.091609 second(s), 18 queries .
