Lincoln Mig 140
发表于 2021-9-1 23:14:05 | 显示全部楼层 |阅读模式
Need a little helpMy Lincoln 140 just started going bonkers on me.  As soon as I strike an arc, the machine short cycles, turns off, and then resets. No welding. What is the fix ????
Reply:simple start is to take everything apart and reassemble - that will at least rule out any mechanical problems and it doesn't cost anything.Awhile ago a member had a piece of the filler wire rubbing on the case as the spool turned.Hope it's something simple.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-19 20:47 , Processed in 0.100155 second(s), 18 queries .
