What is the best way to run air compressor lines
发表于 2021-9-1 23:13:59 | 显示全部楼层 |阅读模式
What is the consensuses on running black pipe for and air compressor to trap moisture pre separator? I want to make mine tight and concise due to small wall area.I have done searches but there seems to be no rational and maybe there is no wrong or right way.
Originally Posted by smithdoor
I use 1/2” galvanized pipeBlack will rust out. I would put a tee every 10 feetDave
Reply:I would use black pipe, galvanized has a coating that can flake and damage air tools. Never had an issue with black pipe rusting thru in an inside application.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Black Pipe. Keep the runs slightly pitched so water can run to a low point and be drained. That said I have a copper system only because I started with the copper about 30 years ago. No problems with the copper but probably expensive today.Ernie F.
Reply:I run black pipe also, if I started over I would run minimum 3/4 for the drops and bigger for the main feeds. But no complaints with 3/4 and 1/2 for most things. Have a drier and filters on the inlet and a couple down the system as well.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:I will post a picture in a few hours and the logic behind my set up.Thanks for the help
Reply:In our plant we run Schedule 80 CPVC for all our air.I was always under the impression to not use galvanized due to the potential of flaking.
Reply:Here is a few pictures. Each pipe is 4' long and the top pipe which runs to the right is 8' or 10'. The second picture has a separator an hose. I tilted the pipes (not level) to aid water to run to the bottom pipe which has a valve. Give me ideas of what need to change.
Reply:You might want to to look at the following before using CPVC for airlines.https://www.usplastic.com/knowledgeb...contentkey=787Mike
Reply:Summit racing sell a plastic air line. Money is tight. I may go that direction. My space is so small I need to max. every square inch. Additionally I want it to look profesional, as you can see in the pictures it looks rough. When people stop over to get stuff I don't want to look like a trash operation.
Reply:https://www.summitracing.com/parts/raa-f28070/overview/I would something like the above for your airlines, looks professional and easy to install.Mike
Reply:Last stuff I ran was pex but also have lots of copper in the finished areas and in some of the fab shops I also have several hundred feet of poly buried between buildings and another hundred as a main feed from one end of my sawmill building to the other end. I find the pex tough and simple to install, have seen summits pex/Al pipe... It looks nice but for the premium in price I can plumb three times as much shop in regular pex
GMT+8, 2025-12-19 21:02 , Processed in 0.110740 second(s), 18 queries .
