Advice Fume Extractor
发表于 2021-9-1 23:13:59 | 显示全部楼层 |阅读模式
I want to get a fume extractor for my garage. Space is a premium my LWS sells The Miller FILTAIR 130. Any one use one. The garage door open and fan at the other end is not getting it done, plus its cold as hell.
Reply:I have a coppus.  The small ones are really for specification locations. Kinda a pain to move to every joint you weld, but works. I use it onsite.  In addition to an extractor you might consider an air scrubber.
Reply:I just sold my Miller 130 Filtair lately......
and use the blue Covid masks they hand out free at the grocery store.
Sent from my iPhone using Tapatalk
Reply:Lis2323Did you like the Miller 130 Filtair? I'm going to try the covid mask. I'm making 2500 brackets and will have a lot of hood time.
Reply:I understand. I may fix it to a wall or hand from the ceiling. Just working in a 2 car garage which I share with my hobby car, space is a premium to say the least.
Reply:Do some research and see who makes that unit for Miller.  Like everything else you are paying for the name. That model would be easy to wall mount. Just unscrew the casters and put it on a shelf.  Sent from my iPhone using Tapatalk:
Reply:Has anyone ever took one apart to see how its made or what it would take to build there own.
Reply:How about using a standard shop vac with a HEPA filter installed?  The fumes we don't like to breathe are basically the visible particulates (what causes the smoke to be seen by the naked eye) and certain to be captured by a standard vacuum with a good filter.  You could even build a box to hold a second filter inline somewhere if you wanted more protection.I visited a shop last year that had a very "simple" solution that amounted to nothing more than a 6" flexible duct that ran from the work table to the wall where there was a standard exhaust fan built in.  He'd wired an on/off switch right at the bench so it was easy to turn the fan on when you were positioning things.  No filtration needed since the fan got the smoke up and out of the building rather than exhausting into the building.
Reply:Shop vac would not be the right kind of fan for this.  They are high suction but low volume.  You want to move a higher volume of air but not with a lot of suction power for this.  It is more like ventilation than vacuuming stuff.  A furnace fan/squirrel cage would be more the type.  Just find or buy one of those and add a filter as desired, but be careful the filter is not going to catch a spark and smolder.-DaveXMT304 with: 22A Feeder, or HF251 Hi Freq DC TIG air cooled
Reply:Shop vac's don't work good as fume extractors and can catch on fire. Maybe all you need is an exhaust fan. The Marley Power Cat has hose that can be connected to it.https://www.electricheaterwarehouse....AC_p_1603.html
Reply:I run fans and got a fume extractor. LOL
Reply:I got the miller product, pricey but my LWS stands behind everything they sell. "My nose clean out" is much better, gross but fact.
Reply:In addition to the ventilation - It is still worth wearing a respirator under your hood, especially for the messier processes like MIG and stick.  I always felt queasy after MIG welding a bit in my garage until I started doing that. TIG I don't do it, even though I know I probably should, especially on SS.-DaveXMT304 with: 22A Feeder, or HF251 Hi Freq DC TIG air cooled
GMT+8, 2025-12-19 20:59 , Processed in 0.069779 second(s), 18 queries .
