Welding Cart/Cabinet Recommendations for Multiprocess
发表于 2021-9-1 23:13:56 | 显示全部楼层 |阅读模式
Hello Everyone,I am new to welding and still acquiring my gear.  I have a Miller Multimatic 220 and need a cart to hold most of the stuff and two cylinders.  Most of the carts I see only say they hold one cylinder, or don't specify.  Is this true or can they all hold dual cylinders?  I do not have giant cylinders, both of mine are small (I don't recall the size at the moment).  They are about 30" tall.  Any recommendations? I was looking at the Klutch Cabinet from Northern Tool.  The local Harbor Freight has a similar one by Chicago Electric but they both only seem to hold a single bottle.Cheers,Andrew
Reply:Miller makes a perfect cart and dual bottle conversion. I run one under my Multimatic 200. Sure makes it nice with both gases already connected. Mig to tig with flip of a switch.
Reply:I found if use hose and place tanks on wall it easier to welding machine around the shop. My cart has very little on cart to keep weight down. Dave
Reply:If you can't find exactly what you want, make it. Welding carts are really good, and useful starter projects. I made both of these.( the MIG cart has 2 bottles)
Reply:Thank you everyone for the input!  These things are hard to come by (like everything else)  Everything is out of stock or weeks out haha!
Reply:This my welding cart.It built low to ground so does not tip over. Planing on installing larger wheels so rollers betterDave
Reply:Lets see, you can't find a cart for your new WELDER and wondering what a good first project might be? HMMM...
Reply:Here’s a couple of pics of the typical two bottle carts I have...
Sent from my iPad using Tapatalk
GMT+8, 2025-12-19 20:57 , Processed in 0.094825 second(s), 18 queries .
