Longevity Weld Max LC-416D stopped working
发表于 2021-9-1 23:13:50 | 显示全部楼层 |阅读模式
I have had the unit for several years and only used the plasma cutting function. Recently, I needed to use the stick welder on my tractor. I'm a complete beginner with stick. I managed to burn through half a rod before it died. I now get nothing to work. I was running the machine on a generator and stopped for a second to grind off one of my many mistakes. The grinder was also running off the same generator. The generator came under a heavier load for a few seconds as I was grinding. But did not trip any breakers. I went back to the Longevity and the display was blank. I tried every function and nothing worked. The translucent power button on the back is illuminated and I confirmed it was getting power with a multi-meter. Emailed Longevity for help and any documents they still have. I was told they could send the wiring diagram and I qualified for 15% off purchase of new unit. But otherwise, no help. Still have not received wiring diagram.I haven't found much information about this unit and I'm trying to figure out if I can repair it or just need to cut my losses.Thanks
Reply:I have a 520D and my switch just died.  I was getting power in but the contacts burned out. I suspect that if it's not something simple like the switch it's not worth spending the time to fix.
Reply:Hi there,If the unit is powered powered up, you might want to check if it welds or not, even though it looks dead.I assume it would return to the last used setting (stick).If it doesn't weld, you are probably going to cut your losses.If it DOES weld, then fixing may be OK and not too nasty ... Or not.Depends what the debug exercise turns up, assuming that the clowns at HQ step up.Andrew
GMT+8, 2025-12-19 20:55 , Processed in 0.071075 second(s), 18 queries .
