120V PowerPlasma 25i XTR
发表于 2021-9-1 23:13:46 | 显示全部楼层 |阅读模式
Everlast is continuing to challenge the market and open up new market segments.  The new PowerPlasma 25i XTR is now available for sale. This is the latest in the PowerPlasma line.  The unit ranges from 10 to 25 A output with a 35% duty cycle at 25A.It is a small unit designed for the typical day to day needs of hobby, farm, ranch, auto body, and HVAC  companies with 120V supply.  It's perfect for portable operations such as restaurant equipment repair, or with newer engine driven welder/generators or generators that produce clean power.Designed for cutting up to 1/4" on a regular basis, the unit will go up 3/8" for severance.The new product utilizes the Innotec iPT 25 series blow-back type torch.The unit offers plenty of value, starting well under 600.00 with a 5 year warranty. You'll be hard pressed to find anything that rivals this new 120V plasma cutter for price, warranty and capability.EDIT:Here's a link to the website:https://www.everlastgenerators.com/p...plasma-25i-xtr
Last edited by lugweld; 05-25-2021 at 12:10 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Not really seeing much of a challenge in performance 25 amps output on a 30 amp circuit .  I get a bit over 18 amps output on a 20 amp line even with a compressor built in The Ironton 30 or jasic will smoke that thing on any thicker stuff..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:LOL. That cloud that follows you eventually sends a bolt of lighting right into your tail feathers.  But I suppose I should thank you for the opportunity to talk more about it and compare.First, the ironton is 120 and 240V, which is rather vague on input/output requirements and requires a 30A breaker...according to Northern Tool's  site...but from their manual it says 20 on 115 and 30 on 240V.  Is that inrush or operation? Not clear.Ours is 30A inrush, operating at 18A. Others smoke it? Not according to our tests.  Just sayin'. Not on 120V.  Stay tuned for the videos and tests on the 'tube.  (But you may see smoke from those others literally soon after you buy them and no support or warranty...1 year versus 5? Full free, live phone and email tech support, along with forums, and  multiple, heavily viewed and active social media spots for support that they can contact versus what exactly? An email box to send something to? lol....get real on the comparisons.)Most people find our cut data to be on the conservative side....and I suspect they will once again find that to be true on this unit.A lot of people don't have 240V, so the extra 3 or 4 amps you might get on 240V operation (30A) never materializes.   Most dual voltage plasmas are either 25/30A or 27/30A output on `120/240V respectively.   120V output is always lower or there is some caveat. For those people that have only 120V, and want a MIG and a plasma cutter, but can't swing the 240V, we deliver.   Our 120V model MIG has proven to us there is a huge demand for 120V only products that deliver on performance.  This model is designed to appeal to those same customers....plus a number of people who need to go portable where 240V may not be available. The dual voltage appeals to people who may need to go portable, but have a standard 240V outlet...but this appeals to a larger market segment overall.AS far as the Jasic/Razor weld product, we all know there are huge issues with the razor weld stuff and changing torches and design constantly.  And they don't even publish their specs. The number of customers I get that come over from Jasic/Razor weld is surprising on plasmas...and they are blown away by our performance differences, time and time again.  I've put it out there to customer and after customer they'd be pleased over the razorweld/jasic cut, and they come back to me that they are thrilled by our huge performance gains (and support).Both are using the old generic trafimet design torch.  Ours are using the Innotec design blowback models...which improve cutting ability.Built in compressors are notorious for compressor failures, and have a relatively short life span if leaned on too heavily. They've been around 25 years.   Nothing new to that tech. Thermal Dynamics "Drag Gun" is one such example.  The compressor technology unfortunately hasn't made a lot of improvements since then.    We had that option open and comparatively reliable, but life span on a heavily used compressor is only about 3 to 4  years on a unit like that.  Obviously, we went another route.  And it is light, really light by comparison.Last edited by lugweld; 05-25-2021 at 12:06 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:My 2007 15c is still running strong. The ironton will output a true 30 amps on 120 power cuts 3/4 on 30 amps 120 input.. I used it, and owned one too. The Korean  made compressors work excellent over the long haul. I have a 35c, and 15c.. Talking to the wrong guy with your smoke screen.Blow back just means a larger front end to me..If you had some real tech that Hypertherm or even Thermacut has in there nozzle/etc designs, then you might have something..Blowback /blowhard, means little to cutting  performanceI am guessing you can show me some nozzle patents that improve performance over a  real good torch?  The USA draggun/plus was never a very good machine.A 15c running off a lightweight inverter 120 volt generator will be a much better portable unit then your 120 volt machine on a the same generator, and a air compressor Hands down better 120 volt portable setup. Just does not work well at all.Unless you add about 40-50 pounds  and another $500 to the genny.Same goes with a Hypertherm 30 air.. lighter then a compressor and plasma cutter too.Last edited by Brand X; 05-25-2021 at 11:00 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Just to show you how we rate our product, this is one of our TIG/Stick/Plasma (PowerPro 205si) units with a 50A plasma we rate at 3/4" severance. This is a customer photo they posted on the Everlast Welders Facebook page cutting 3/4" plate.   And, it has more to go, but this is where we conservatively rate the unit.But really, you are missing the point.  A person with 120V input isn't going to be welding 3/4" plate so the point really is moot for the most part, unless it is an emergency "hack through" type cut.  They will be welding with a 120V MIG, TIG, or Stick unit, or some combination of the two or three processes.   And that is limited as well as to what they can do.  A 25 Amp plasmais able to cut a stated 3/8" is more than capable and a perfect match up to those type units.Face it, you are here to throw off and detract as much as possible, using red herrings and bull poop to do it.
Reply:Dimensions of this unit are :  13.75" L X 5.5"W X 9" HWeight is 14 lbs. bare unit.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:We let our customers do that. Go to one of the Everlast face book pages and there are plenty sharing videos.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I am not on facebook though.  I can find one video on youtube and the person pointlessly cuts 1/2" steel.  Even a super cheap 40 amp plasma can do that.Last edited by .RC.; 06-07-2021 at 05:30 AM.
Reply:Face it, you are here to throw off and detract as much as possible, using red herrings and bull poop to do it. At least I am not selling anything .. Seems like your company started out the bull poop way,and has took it to another  level through you..Pretty much a snake oil salesman of higher the caliber  . I seen this game before, and it never changes.I was just calling you out on stupid claims you made about other machines, that you have not used, and have zero knowledge about . That does not distract anyone, just lays the steaming pile at your feet.
Reply:There are very few makes I have not used and many many models within the makes that I have used as well at least once, if not for anything but testing.  I also study the competition very very closely for hours on end.   You make an Assumption.  You are the one making stupid claims, that you cannot back up as I think I proved.  If you want to carry this on, fine.  But I think you ought to drop it.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 20:55 , Processed in 0.095662 second(s), 18 queries .
