Lincoln LF 74 Wire Feeder on 350 MPI?
发表于 2021-9-1 23:13:43 | 显示全部楼层 |阅读模式
Hi there,I recently picked up both a 350 MPI and a MTS 3500 for a pretty good deal.  I would like to run a Lincoln LF74 wire feeder on one of them.  In reading old threads I gather that this combination is possible (thanks Brand X!).  I intend to make my own cable.  I have the pin-out diagram for the 14 pin Lincoln connector, but cannot find the detailed pin diagram for the Esab 19 pin connector.Can anyone help me out on identifying which pins to connect up when making up my adapter cable?Many thanks!-Dave ps - I am also looking for the high frequency tig starter box (EAS-IV) that was available for these machines if anyone has one available. . . .
Reply:Give me some time, and I will get the pin outs from the adapter I still have. If you do find that box, be sure upgrade the fuse running the control circuit in the 350MPI.. They came undersized for that box. It will blow and you will think the high voltage box is dead. Don't ask me how I know that..
It's high voltage start,but similar to high freq start.
Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:go to ESABNA web site. support tab, documentation then user manuals.arc equipment, power supplies, multiprocess. 350mpi will be at the top of the page.down load manual 15-481-K. go to page 43 to the machine diagram.right hand side.  labeled J1 is the pin call out for the 19 pin plug.right in the center is the 115 and 42 volt circuits. don't mix them.The LF74 runs on 24 to 42 volts. go to Lincoln's web site. support tab then parts.open the service navigator and enter as a guest. place code number in the box and get access to the owners manual and more. print out diagrams and match up the plugs. so the welder can supply what the welder needs.The only odd thing you will need to do is connect pin J1-V on the welder to pin c and pin I. This will allow 42 volts to go to the contactor control and return out D to J1-UOn the feeder C and D are contactor control and is a opto isolated relay.I and K are the 42 volt input.(J12) to power the feeder.on the welder T and U are 42 volts. V is the contactor return.Ground connection to J1-D is not needed on a 42 volt system it is for the 115 volt.You can also use the 14 pin plug and power it on 24 volts. same type of three wire system plug J2 Please check these instruction against the diagrams. before you make up your cable.
Reply:If you are going to use the electronic voltage box,(ft pedal too) it uses the 14 pin on the MPI.. So wiring the feeder to the 19 pin is best.It also will allow the LN feeders to run full speed when using on .023 wire.. Only downside to running that feeder on 24 volts..Which I do with a Lincoln to Miller 14 pin adapter running the LN-72/74 feeder. I use it on my Thermal-arc LM-200.. Great versatile feeders!Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Thanks a lot for the feedback gents, appreciated.  I actually had the full manual for the 350 MPI downloaded, but did not notice the wiring schematic has the the pin out!  I am waiting for my end connectors to arrive and then I'll give it a shot.  I considered buying a cable at first and called the guys at Justarc.  I left a message explaining what I needed.  He called back and left me a message saying it was "impossible to make these European standard welders work with a Lincoln 42 volt feeder, and that in all his years of business he had never successfully done it"  I found that interesting/amusing based on what I have researched here. . .  In any case, I'll tackle it myself and feed back my progress (or lack thereof) when I get all my parts ready to assemble.Thanks again for this great resource!-Dave
Reply:bunk postLast edited by Brand X; 01-08-2021 at 12:19 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Dea, from Just arc made my cable adapter for me..He just forgot..(LN-72 14 pin to Esab 19 pin) He also gave me Pin outs on building a cable for a 120 volt Hobart feeder 17A to the 19 pin Esab. ccawqc also came up with the same info on hooking up a 120 volt feeder to a MPI. The 350 MPI was made in South Carolina , I believe the 3500 was made in Brazil. Main thing,what you are doing is possible, and will work great when done.I can see the Esab Aristo euro power supplies being impossible to get to work with the Lincoln feeder.. I bet that is what Dea is thinking.Last edited by Brand X; 01-08-2021 at 12:23 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:pics of Lincoln feeder to Esab 350 MPI By Justarc..
tig box too..
Last edited by Brand X; 01-08-2021 at 02:33 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Wow, that's a well outfitted welding cart
very nice!  Thanks for the info, it does seem Dea may have been mistaken on what I wanted as it was an exchange of messages vs a real conversation.So I have started to generate a little diagram for my cable using the manuals for each machine.  Is anyone on here capable of double checking me?  I'm not really all that electrically inclined and some of the descriptions on the drawings are pretty brief. . . .   In the Lincoln manual there is some detail on how to connect to a Miller power source and that was somewhat helpful.  It does seem that there are a lot of pins I am not using though.  It seems like L,M, U are impt on the Esab side, but I don't really know where they would go. . . Brand X - I'd love to have your cable and spend a few minutes with a continuity tester to confirm what goes where!Short of that though, can anyone have a look at my diagram and critique it?Many Thanks,-Dave
Reply:Three wires to the MPI is correct.. not looking at pins, just the back of the cable adapter. I will look over the adapter later..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:My cable reads 14 pin female to feeder---------- 19 pin male to 350 MPID    ------------------                           UC+K------------------                            VI  -------------------                            TLast edited by Brand X; 01-08-2021 at 09:16 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:the aristo feeder uses digital communication I believe. so it can only be connected to an aristo welder.
Reply:Well I thought I’d post a follow-up, it’s alive!  After my end connectors came in, I took a length of seoprene and tested my soldering skills (and patience!) and made up a cable per Brand X’s pinout above. Works perfect!  I also had to make a new 14 pin pigtail for the wire feeder... despite being shown in the auction pics, it showed up without 2 critical little connector cables and the main 14 pin plug on the back. But some ebaying and soldering later and i’m in business. Thanks to this forum!
Reply:Got a cart fabbed up and getting her dialed in. Love this Lincoln/Esab combo!-DavePs- Still looking for Esab EAS-IV high voltage Tig starter box if anyone has any leads.
Sent from my iPhone using Tapatalk
Reply:I had the 4-30 esab feeder with Pulse. That was a really great system. The Lincoln feeders are super versatile, and I have the LF-72 0n my Thermal /Sanrex LM-200.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Brand X- Do you know if an Esab Digipulse wire feeder will work with a 350 MPI?  Would be nice to have pulse mig option Sent from my iPhone using Tapatalk
Reply:No, it will take a 4-30 or 4-48 HD feeder with the pulse panel There is a Pulse box too. Had one along the way.. I think a 4hd feeder is needed to get it all to work correctly Had one of those feeders too..
https://www.esab.ca/literature/arc%2...l_15-606-a.pdf
Last edited by Brand X; 01-31-2021 at 11:19 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Cool, thanks. I’ll keep my eyes on ebaySent from my iPhone using Tapatalk
GMT+8, 2025-12-19 20:59 , Processed in 0.093871 second(s), 18 queries .
