migmaster 250 volt/ammeter
发表于 2021-9-1 23:13:40 | 显示全部楼层 |阅读模式
Hello all, has anyone made their own volt/amp display or found a ready made one that works? The original accessory display is long obsolete.I have searched but have not found anything,but possibly missed it. Thanks, Jim
Reply:How about something like this?https://www.amazon.com/DROK-Multimet...9208874&sr=8-9
Reply:[QUOTE = rexcormack; 8811094] Как насчет этого? https://www.amazon.com/DROK-Multimet...9208874&sr=8-9 [/ QUOTE ]I wonder how reliable this option is?
Originally Posted by Jack Ryan
This meter measures AC current and voltage and may respond to DC but the specified voltage range is 130-500 VAC. The maximum open circuit voltage of the welder is 55 VDC and its rated output voltage is 27 VDC.It's a good starting point though.Jack
Yeah, I missed the dc part, dang it!Try this. It has a lot of functions that wouldn't get used but it does cover the volts and amps needed.https://www.amazon.com/Electricity-M...9700876&sr=8-4 Rex
Reply:There are some good analogues on Amazon, though!
GMT+8, 2025-12-19 20:59 , Processed in 0.090070 second(s), 18 queries .
