phase converters
发表于 2021-9-1 23:13:39 | 显示全部楼层 |阅读模式
How does one figure out which one to buy?  Have esab 875  Anyone else ever heard of this problem and/or what would be the solution?
Reply:Which 875 do you have? Looks like some are 230v 1 or 3 phase,some 460 volt 3 phase, some 50 hz, etc.  Didn’t see any 230v.60hz 3 phase.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:230 v 50 hz
Originally Posted by Harryvan
230 v 50 hz
Reply:A pic of the rating plate would be immensely helpful.
Reply:The stick and tig take a large converter. Mig welder takes a smaller size.I build mine it can be simple as using a single phase motor 3/4hp and a [three phase motor star wound 5hp] at same rpm. This will run very large welderDave
Reply:I believe you will get much more response if you post your question in the electrical section right here:   https://weldingweb.com/vbb/forums/35-Electrical
Reply:If your machine needs 50Hz, thats not something that a typical phase converter will be able to give you if it is operating off of 60Hz "power".  It wont change the frequency of the input voltage waveform.
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:In America it is 60Hz.I have only seen equipment that was both 50Hz and 60Hz. Dave
Reply:Yes I'm aware of that.  The OP mentioned 50Hz input, hence my post clarifying the difference.
Reply:Sounds good👍Dave
GMT+8, 2025-12-19 20:58 , Processed in 0.071463 second(s), 18 queries .
