Linde V-160 manual
发表于 2021-9-1 23:13:38 | 显示全部楼层 |阅读模式
Hi, I just acquired a Linde V-160 Migmaster, serial number 138695. I'm looking for the manual (P/N L12-852). I found a few links on the web but they are incomplete, only 6 of the full 15 pages. The torch is missing so I'm wondering what would be a suitable replacement for the original MT-200 torch (P/N 948911) and the wire feeder connector (P/N 2075380) that came with it. I heard that these are great machines. Can't wait to use it. Any help will be greatly appreciated. Thank you.
Reply:Call ESAB tech support. They should be able to give you a choice of a couple of tweco guns that will work on your welder. At one time they had a conversion kit so the MT200 could use a different type of consumables Tweco is part of the ESAB family of companies.Try going to ESABNA.com dig around in the download archives you might find a manual. Send me a PM if you can't find anything. I might have a paper copy I can scan. will have to look through 7 or 8  2inch binders of old manuals.
Reply:I spent quite a bit of time searching through the ESAB support documents for the manual to no avail. If you could find yours and scan it I would greatly appreciate it. Maybe it can then be added to some support database here for others to use too.  Thank you.
Reply:will need you to send me your email by PRIVATE message.Make take me a day or two to find it and scan it.
Reply:Esab tech support is usually pretty good if you get the right person. They will be able to tell which newer guns will work.
GMT+8, 2025-12-19 21:13 , Processed in 0.105466 second(s), 18 queries .
