Titanium 125 Easy Flux welder is a gem -- even with a 3800-watt generator!
发表于 2021-9-1 23:13:10 | 显示全部楼层 |阅读模式
DIY weldor here!  Anyone else using their HF lower-voltage Titanium welders with a generator?  Just curious to know of the results that others are experiencing.  It's wonderful to have the option to grab a lightweight welder for small jobs that I can do almost anywhere.  I primarily use mine portably with a WEN 3800-watt generator with no issues whatsoever.  And although I've only used the welder 4 times over the last couple of years, for small jobs (e.g., custom bracket to affix gauges in Jeep engine compartment for on-board air system to run power tools/air up tires, fixes to metal lawn chairs for my neighbors, golf cart's canopy fix for a local high school, fix a neighbor's metal bike rack), it always impresses and performs flawlessly.  I just use Lincoln .030 NR-211 flux core.   But I was curious if anyone else uses their Titanium welder with a generator and what are their experiences when doing that.Agape GuyEverlast Power I-MIG 200 (dual voltage)Everlast PowerArc 200 stickHarbor Freight Titanium 125 Easy FluxHypertherm Powermax 30Way too many power tools
GMT+8, 2025-12-19 22:24 , Processed in 0.095389 second(s), 18 queries .
