Miller Bobcat 225 NT won't stay running
发表于 2021-9-1 23:13:07 | 显示全部楼层 |阅读模式
I have a Bobcat 225 NT with an Onan P216 that will start and run, but dies as soon as I let off the ignition. New ignition switch. Neighbor came over and ran a hot wire from battery + to coil +. It started up, and ran until he removed wire - didn't run it very long. He know's enough about small engines to try that, and I know even less than that. I'd really appreciate any help that anyone can offer! --------------------- John
John
Miller 320 A/BPMiller Auto Arc 50Miller 150 STHLincoln SP-200Hobart "Mainliner" GeneratorPlasmaFix 50S Plasma WelderThermal Arc Pak 3XR Plasma Cutter
Reply:Thank You!! I bypassed the switch, it started right up and ran. ---------------------- John
John
GMT+8, 2025-12-19 22:11 , Processed in 0.102512 second(s), 18 queries .
