1953 i believe, gotta ck a lot stuff out b4 trying 2 start. I removed the enclosure 2 get better views. I plan on disconnecting while getting the engine running. Can the welding machine be dated by serial number? Ur comments be welcome, especially the condition of the welder after viewing photos. Where do I find maintenance info 4 this welder? Last run 15 years ago as told owners son.
Reply:more pics
Reply:That is a fine looking machine you have there! Have you tried the codes on Lincoln's site yet? Some of you will correct me if I am wrong here, but I think I have heard of those units being sold and commonly put on draglines and such which would fit your year model nicely and engine size for the popular smaller machines in the post war building boom. To be sure, you have a treasure there. I would love to see her running.SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Thats a big girl.AWS CWI xxxx21711968 SA200
Originally Posted by WelderMike I hate being bipolar, It's awesome.
Reply:The serial # shown makes your machine a 1955. That's quite a welder! Looks like it needs a little elbow grease to get it right again. Good luck!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Don't know your age. Are you familiar w/ the operation of the pony motor and especially the operation of the clutch and pinion to make the pony turn the main engine? I worked w/ these type of Cat engines long ago, so if you have questions I'll try to dig deep in my memory banks to get answers. MikeOl' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:When 12V71 mentioned fuel, something came back to me. I see evidence of oil leakage on the injection pump, so unscrew the slot head plug on the bottom of the pump. The oil level should be at the top of the opening and about the consistency of 10 wt. If it's really thin drain it and refill w/ 10 wt. This pump has it's own oil supply so should be checked on a regular basis. If the pump has internal fuel leaks and it runs over when the plug is removed it needs to be drained and refilled. MikeOl' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:With the welding machine disconnected i got the starting and diesel engine running
Reply:That is one cool machine would be just great to weld with good luck with it
Reply:Looks like you're old enough to know most everything about it. Regarding the pony clutch and pinion, if you pull the clutch handle hard opposite of engagement the clutch brake will stop everything from clashing gears and the pinion has to be held in position while cranking and as soon as the main starts, release the pinion handle. At least that's how the 8800's, 342'S and 353's I worked w/ worked. They were all stationary engines we used to power rock crushers. MikeOl' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Time to get the welding system in order now. I hate to see how much fuel this unit burns.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:You just have to love old mechanical diesels. If you have air and fuel, and they turn over, chances are they run..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:thanks for the video! i very much enjoyed it and cant wait to see your progressbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:we can help you with the welder part!!!!not that im a whole lot of help, but i can tell you what the others on here have told me!bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Cool video. Thank you very much. I love to see old iron being resurrected. Quite honestly, due to the possible value of the welder portion of that machine I would get a knowledgeable welder guy to look it over in person.
Reply:operation will be very similar to an sa-200, and there is a wealth of information on them. this will help you get started i hope. they are simple machines.https://www.weldmart.com/main/techni...eshooting.htmlbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Originally Posted by wrenchguy
Its been sitting 15 years and i don't want to mess anything up pertaining the welder, thats why i disconnected it. Should i contact a repair shop and ask where to start?
Reply:Thanks so far, i'm learning. I'm concerned about how dirty looking the commutators got when i went 2 inspect it. i was able to turn the engine over a have a half turn 2 see if it was locked up. I noted the armature turned too and the brushes seemed to be leaving a dark residue on the commutator "see photos". I stopped turning the engine by hand at that point. My concerns about the commutators and possible dry armature bearings are the reasons why i disconnected the welder from the engine. Are the armature bearings sealed? Its been sitting a long time. What do i call the welder part of the machine, sa-300x2?
Reply:your welder(s) are sae-300's by the looks of things, with one exciter.the exciter is foreign to me, but the main generators are pretty generic as far as i know. the difference between sa and sae machines as far as i know is in the coarse or main current control. the sae uses a . . . . .reactor? (cant think of word) that can be set in infinite increments, instead of a 4 or 5 position switch to choose rough operating amperage. the "fine" or "job selector" in your case controls ocv and as a side effect, affects output amperage. it is sourced off the exciter and controls (through a simple rheostat) the amount of juice sent to the shunt coils in the main generator, which decide how much juice the main generator will put out.exciter has permanent magnets, but they can go "dead". they can be refreshed via the link i sent you. the main generator(s) use electro-magnetism, from the exciter, to generate power. no exciter= no generator.so the welder part of this machine is very similar to the engine part. there is the main power-source, but it cant work without the pony-motor to get it going (exciter). the pony motor only works if the battery (magnets) is charged and able to start the cyclebosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Essentially you just have two SAE 300 welders. The commutator bars can be cleaned up easily with 320 or finer grit sandpaper. It's easier if the brush racks are off and out of the way. The dark residue is just carbon that the brush is made of. On the subject of brushes, your 4th picture shows what appears to be a missing brush and springs. But without knowing how this machine was originally configured I can't say for sure. I wouldn't be immediately concerned with the bearing(s). If it turns, I'd leave them alone until you verify it will even weld. I'd venture to say the brushes need to be removed and the holders cleaned up so they will slide in and out. There's a real possibility you will need to flash the fields to make it weld if it has sat for an extended period of time. Getting ahead of things though. Let's dig in on that missing brush or is this correct for the twin setup?Well dang, 92 above beat me by 3 minutes.
it looks like the "missing brush" is on the exciter. . . .which was apparently made in spanish cause i dont understand it. . . . . . .ive jumped a few times scrolling down and seeing it that way, but it was apparently run for a while like that so im guessing its factory. . . . . kind of weirdbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:If you consider cleaning up the commutator with sandpaper do not use emery cloth!! The abrasive is conductive and will wreak havoc with the machine electrically if used and not cleaned out thoroughly. When I mean thorough, I don't think you could clean it up sufficiently and it remain together.Best purchase a commutator stone to dress this item.SlobPurveyor of intimate unparalleled knowledge of nothing about everything.Oh yeah, also an unabashed internet "Troll" too.....
Reply:bwparts.comstumpfweldingsupplies.combillswelderrepair.comweldmart.comall good sources of information and helpful people in my experience. i hope i didnt leave any outbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:4th pic is left side of exciter, 8th pic is right side of exciter.
Reply:I hope 1 day to make the welder run and look like this project i just finished, i'm nuts 4 old Caterpillars.
Reply:There is a like machine on ebay now. This one is set up for dual operators. I don't think this one is as old as your machine.http://www.ebay.com/itm/221837013504...%3AMEBIDX%3AITDan DManipulator Of Metal
Reply:Did you get this machine to weld I was just curious ?
Reply:not yet, picking up new axles 4 it this week, got 2 make it mobile b4 going further
Reply:the ebay machine above has been purchased by a caterpillar collector and heading to Minnesota, its a 1963 model using a cat d311-h engine.
Reply:brochure pages of my Cat d315 twin arc welding machine.
Reply:Today i recoupled the welder to engine, removed brushes, cleaned commutators, reinstalled brushes. I noted the chips and grooves the brushes showed b4 installing. They maybe original to the machine. I covered 6 bare wires in control boxes and 1 on the exciter temporary with tape. Machine #1 would strike arc but not able to continue a bead, but more than just sparkle. [kinda hard 2 explain]. Machine #2 seemed to weld ok but not super with the 1/8" rod i had. 1 brush tension spring mount tang broke while messing with the exciter brushes and didn't hold correct tension. Am i correct assuming both machines work off 1 set of exciter brushes, and can i move the exciter brushes to the other mounts? thanks 4 looking & help.
the gobs in the center r from machine 1, the beads left and right of center r from machine 2.
The welding machine commutators kinda glazed up after a hour of running????
Reply:Thought i'd share some info from Lincoln about this 2 operator welding machine, mentions my code number at bottom of page.
wiring diagram 4 my machine.
Reply:That's pretty neat.
Reply:I saw your build on smokstak - cool! This place is the Lincoln experts.... judging by the weld and the appearance of the machine I wonder if the exciter is doing its thing, and is all the juice reaching the main generator?Use a bigger hammer.
I have a local help who is proficient with motors and generators. We are going to repair and rewire everything we can reach. Every connection is rusted/corroded bad. I been reading alot about the Lincoln builds here, especially the shortys, i guess i'm working on a extra longy being the hood is just under 10'.
Its in disassembly now.
Reply:more taking it apart.
gallon can of thinner for size comparison.
reactor for machine #2 that wouldn't make a bead, it has disconnected/broke electrode strap at the connection at the bottom outa sight.
Reply:more taking apart which i'm good at.
at point of pencil cardboard broken away with windings showing.
skid turned into trailer.
Reply:Nice Job so far Mike! Keep at it even if the weather turns foul! Jeff
Reply:Looking good Mike. Man you have really got into yours. I got mine setting in the shop also. Will have to start a post with some pictures one of these day. Just been real busy with to many other projects. I hope I dont need have to go as deep as yours. Mine welded great when I played with it one day but need paint and some cosmetic work along wih new axles.
Reply:can someone provide the test values of the fdr 125 b exciter coils used on my sae 300 welder ?
Reply:pounding out dents, taking most parts to bare metal removing loose and feathering the mill scale, priming and finish paint. 1 bite at a time.
bare metal fuel tank in back ready for primer
