SA 200 Rear Motor Mount
发表于 2021-9-1 23:12:59 | 显示全部楼层 |阅读模式
Does anyone have a few pictures of how the motor mounts are installed on an SA 200 (F163 - Code 8023)? I have two metal plates and two mounts and I think one goes on the stud from the engine and one goes under the cross member that supports the engine but not really sure.
Reply:pretty sure need  to make sandwich , square washer ,rubber and square washer  ,nut and round washer under frame ,will double check when get home from work
Reply:The Rear mounts I get in a package come with: 1 square rubber mount, 1 round rubber mount, 2 washers, 1 bolt, 1 self locking nut, per side on the generator mounts .The Front engine mount uses: 1 screw in stud, 1 self locking nut, 2 square rubber mounts, 1 small round rubber insert that goes between the two halves in the frame, and 2 square metal plates.Last edited by BYW200; 2 Weeks Ago at 11:05 PM.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
GMT+8, 2025-12-19 22:11 , Processed in 0.091900 second(s), 18 queries .
