We Need An SA-200 Info/FAQ Sticky
发表于 2021-9-1 23:12:57 | 显示全部楼层 |阅读模式
ZTFab, think we can get a sticky up with SA 200 FAQ's. Part Numbers, distributors, general info and links. Some basic motor part numbers here. Spark Plugs(you need 4
) Champion D-16 gap .025Oil Filter, Fram PB50, WIX 51050, NAPA 1050, Baldwin B50Head Gasket, Fel-Pro 7183PTCarb kit for a Marvel carb, NAPA 2-1401A great SA-200 Link www.weldmart.comIf we can sticky all this stuff that would be great.
Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:I second that! Torque specifications would be good also......
Reply:I think that would be cool as well. Isn't it amazing the popularity of the SA-200, especially the old one.  It's almost like a cult following or something.  I used to think they couldn't be that special, what's so special about them.  People say they are the best welders made bla,bla.  That was before I owned one.  Now I drive around and look for another old one to pull out of the weeds and fix.  I've had mine running for two months, and have used it at least 5 times a week after work and on Sat.  I don't know how I got along with out it.  I know eventually I'll run out of stuff to weld, and it'll go back under the shed, but I'll never not have one.
Reply:Thanks for the great suggestion guys. I'll get working on it.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:I Was working a job in Baton Rouge and this pipe welder told me about the sa-200 "Red Face" and I knew I had to get one. Later, My GF on another job told me he had one at his house in TX and said if I came down, he would give it to me. The engine was locked up. Anyway, on my way to TX, I found another one on a trailer and bought it for $500.00 and brought both home. On the way home, I found another for $400.00, which I will pick up within the next month. I have the one on the trailer dismantled and will start on an engine rebuild as soon as I can. I have a strong background in auto engine repair, and 20 years of body repair and paint (Air Force). I plan to rebuild all of them and sell one or two. One thing I can say for sure, they are very well made. I hope to move into pipe welding soon but need some further instruction in getting the root down..............
Reply:Fan Belt; NAPA 5L480WDisclaimer; "I am just an a$$hole welder, don't take it personally
Reply:Do you know thepoints setting for the SA200 . I dont know the year I just got it and I am tring to get it going .
Reply:Set tee points at .020 and you should be good to go. The ones in mine are still eyeball gaped and she runs fine.Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:Thanks for the info on the points .That works fine I now have fire now I think the carb is poss. full of crap as it sat for about 5 years .It dosent seem to be getting gas .It turns and fires but the plugs stay dry .It did pop a few times on starting fluid .Is there anyway to tell the age ??? Thanks again...
Reply:I just "rebuilt" the carb on one I just picked up with 2 cans of carb cleaner. It runs and welds ok, but needs a real rebuild in the future.Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:zenith fuel systems .com has all the rebuild kits for the carbs and they cover the marvel-shrieber carbs as well , there is a company that supplys all the mag parts for both american bousch and fairbanks I have orderd parts from them and they good to deal with , I beleive there called american mag.
Reply:ok (american eletric ignition) has the mag parts plus all the manuals
Reply:Good thread guys. Nothing better than a redface
Originally Posted by TozziWeldingFan Belt; NAPA 5L480W
Originally Posted by thomasg990Do you know thepoints setting for the SA200 . I dont know the year I just got it and I am tring to get it going .
Originally Posted by boilermakerzenith fuel systems .com has all the rebuild kits for the carbs and they cover the marvel-shrieber carbs as well , there is a company that supplys all the mag parts for both american bousch and fairbanks I have orderd parts from them and they good to deal with , I beleive there called american mag.
Reply:oh by the way auto lite spark plugs work pretty well , not every one carrys them but they can be had .
Reply:My old sa200 had what I thought was a magneto problem, so I put the coil and ballest off a isuzu motor and ran it for a year till one day, for no apperant reason, I reconnected the mag and guess what? It works now. hmmmm?  Sweetest arc burning!SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Originally Posted by TozziWeldingZTFab, think we can get a sticky up with SA 200 FAQ's. Part Numbers, distributors, general info and links. Some basic motor part numbers here. Spark Plugs(you need 4
Reply:Upper hose: Gates 20606Lower hose: Gates 20705Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:OK, we will try it.David
Real world weldin.
When I grow up I want to be a tig weldor.
Reply:Thanks Dave.Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:F162 and F163Oil pan set: Victor - OS20509FelPro OS30236Front cover set:(included front seal)Victor - JV894FelPro - TCS54182Valve cover:Victor - VS38083FelPro - Purchased FelPro, but I lost the number.While we're at it, F226 (six cylinder)Head gasket:Victor - 986SFelPro - 7191SCourtesy of Denrep.Disclaimer; "I am just an a$$hole welder, don't take it personally
Reply:stumpfweldingsupplies.comI did a search here and I didn't find a whole lot on the procedure for governor and magneto installation and timing a SA 200 with a Continental engine so I will tell you how I did it.  I know a lot of you know how to do this with your eyes closed but some of us here might not.  Feel free to set me straight if I ain't right.  Well, most of us aint right
I have an F162 engine with a Fairbanks Morris magneto and a Peirce governor.  Yours may be different.  I ended up needing to change the governor.  First thing is to pull the oil bath air cleaner off.  I pulled the whole thing off.  Behind the air cleaner is a hole in the engine plate, inside is a small pointer. A very small, hard to see pointer.  You may have to clean this area to see the pointer.  This is the pointer for the timing marks on the flywheel.  The Lincoln Manual for my welder tells me that this engine is timed off of cylinder #1.  Some are timed off of #4.  Now for those that do not know the cylinders are numbered 1-2-3-4 with 1 being nearest the radiator and 4 being nearest the flywheel.  So pull the spark plug out of cylinder 1.  Place your finger over the hole and turn it over with the starter until it blows your finger off of the hole.  You can't always get the engine to stop in the right place but it should be close.  Roll the engine over by hand one way or the other and look in the timing hole to find a mark on the flywheel.  You are looking for a mark that looks like this          D | CThis is Dead Center or another way to say it is top dead center. Line up the pointer with the slash between the D and the C. Pull the bottom bolt out of the magneto and the top bolt out of the governor.  This bolt goes through and threads into the magneto.  Pull the magneto loose and lay it to the side if the plug wires and the kill switch wire on the side are long enough.  Mine were.  The slots across the driven governor gear should be in the 3 o’clock and 9 o’clock positions or horizontal.  These slots are what engage the magneto impulse tangs.  Now you need to verify that the driven governor gear and the drive gear are marked.  There should be two gear teeth on the driven governor gear marked with a punch mark.  There should be one tooth on the drive gear marked with a punch mark.  This tooth should be between the two marked on the governor gear. Once you are sure that the drive gear is marked you can remove the bottom governor bolt and pull the governor out.  I got my new governor from Stumpf's (thanks Kevin) and that one had the punch marks on the gear teeth so it is easy to put on the new one making sure that the punch marks line up as they did with the old one. Use a new gasket, silicone, gasket cement or whatever works for you when you put the new governor on.  You may also want to give it a few squirts of motor oil into the holes alongside the gear.  This will get oil from the engine when it is running but a bit now won't hurt.  Put the bottom bolt back in.Now for the magneto.  I do this a bit differently than what Lincoln’s Manual says to do.  First you need to make sure that the magneto is going to fire on cylinder 1.  First you need to make sure the kill switch is in the run position (if the kill switch wire is still hooked to the side of magneto.  If the wire is unhooked, the mag is ON, trust me, its on).  Put the number 1 cylinder spark plug wire back on the plug and prop the plug up someplace so that the plug is grounded out and you can see it spark.  Twist the magneto impulse tangs clockwise (while facing the impulse end of the magneto).  It will load up and snap.  Watch the plug and once you see #1 plug fire, snap it three more times. Twist the tangs lightly up to the tension of the impulse. About a quarter turn and it is now ready to fire on #1 again.  Note the orientation of the impulse tangs.  I turn the engine backwards (counter-clockwise while facing the radiator) from Top Dead Center until tang slots in the governor gear correspond with the orientation of the magneto tangs.  Put it on, making sure that the impulse tangs engage in the slot on the governor gear. Put in the top governor bolt finger tight.  Put the bottom magneto bolt snug but not tight, the magneto needs to be free enough to turn by hand. (Here you need a gasket too but you will still need to be able to turn the magneto, how you do it is up to you). Turn the engine forward (clock-wise) slowly to Top Dead Center.  The magneto impulse should snap at Top Dead Center, if not rotate the top of the magneto away from the engine block until the impulse snaps.  Tighten the magneto bolts.  Put the spark plugs and wires back in place and fire it up.  If it ran before you took the governor off, it will run now.If you turn the engine backwards (counter clock-wise) from Top Dead Center about two inches on the flywheel you will find a mark, sometimes a T or a | .  This is the timing mark.  If you use a timing light this is the mark you want to hit.  Here are a few things to know. Engine turns clock-wise when facing the radiator Firing order is 1342Cylinders are numbered 1 through 4 beginning near the radiator and 4 near the flywheelRotor in the magneto turns clock-wise while facing the distributor end of the magneto.  This is opposite to the direction the impulse turns.#1 on the cap is usually the upper right hand tower, but it does not matter where it is, only the order of the wires matter.Try not to be the path to ground when twisting the mag pulse, really you don't want to be.And for all you old hands at this let me know it I am screwing up here.Thanks
Mack
Reply:parts for those mags and the mags are kinda high its cheeper if you look in the right places to upgrade to a dristributer i think all f163 and 162 come with the drive you just have to knock out the plug in the center of the head.     had a mag come apart on an old p&h machine(it was preaty nasty)at least down here in georgia cheepist i could find was 600$ think the hole kit new for a dis. isnt but 300. i found mine in an old forklift i had junked out with the same eng.Last edited by aggmechanic; 02-17-2009 at 11:53 PM.
Reply:F163 manifold gasket Fel-Pro MS 8676 B
Reply:I need some technical help .My sa-200 was welding fine then this past weekend I went to use it and it has no arc . Does anybody know what may be wrong with it ???
Reply:When you put it on high idle does it strick an arc,or if you plug a grinder in the outlet, does it rev up. If it doesn't I'd check the exciter brushes. Make sure they are free and not stuck. If the armature is dirty, get a seating stone and pass it lightly across the armature until its clean. If all of this checks out, look at the weld brushes. If none of this works, go to AWS forum site and scroll down to Gear SA200, and I'm sure that someone be able to help you. Good luck,
Reply:Well, I stand corrected.  Our NAPA used to sell Gates brand belts.  Now they have their own brand that is supplied by Gates according to the packaging.NAPA - XL 25-949015/32" (12 mm) x 49-3/8" (1254 mm)Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Magneto Points Fairbanks Morse
Fairbanks Morse magneto points.doc (90.0 KB, 693 views)"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Fixalinc gave me this but might help others
Reply:Thanks for the interesting and  great suggestion guys.i will give it a try
Reply:Enter welder code number at Lincoln to get the manuals listed for it that can be downloaded.  If code number is missing off your tag look on the generator barrel the code number is stamped there usually beside the starter.  http://www.mylincolnelectric.com/Cat...ualsearch.aspxContinental manuals can be downloaded from Wisconsin Motors site.  http://www.wisconsinmotors.com/partcatalog-ex.htmlWeldmart has a CD can ask them for has lots of good info for SA200 and accessories on it.http://www.weldmart.com/  I have a lot of magneto & carburetor info for SA200 and other welder engines repairing those for 30 years.  PM or Email me for magneto or carburetor parts & service lists.
Reply:Here is a little trick that will make removing the hood easier.The factory bolts have a square head, with a "crushed" nut.  I found this set up to be difficult, especially with a cramped space.  I couldn't get a "full swing" with the ratchet on the bottom.  It took too long to get the nuts off.Plus the "L tabs" want to push through and fall inside of the machine.I gapped the factory "crush" nuts and put a few small welds on both sides.  I replaced the bolts with a stainless steel version that has a traditional head and washer.This now will allow me to remove the Hood hold down bolts from the top, without removing or scratching the paint.If you have ever removed the hood from a Lincoln 200 or 300, you will appreciate this.-Rhyno
07 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others...
Originally Posted by Rhyno
But, if I "all of a sudden disappear....
...." hopefully I didn't suffer too much....
Reply:I gotta say,Im glad I found this forum.I have'nt desided if I screwed up or not.I got rid o a 06 trailblazer 302,So I could start building on a few sa-200's.Thanks to you guys,I found alot of info for my 68.There are some guys up in norman,Ok that have built a few sa's that look nice.The site is [email protected] again for all the great info.Scott
Reply:hey the continental overhaul manual is just click away in a pdf http://www.stumpfweldingsupplies.com...aul_Manual.pdf
Reply:Thinking of upgrading or converting your charging system or alternator, check out this link http://madelectrical.com/Last edited by kolot; 11-03-2010 at 05:15 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Please PM me the same.SEO Agency | Website Optimization | Google SEO | SEO Provider
Reply:What's the oil capacity for the F162/F163 and what kind of oil are you using?StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:For those who have not done the spin on oil filter conversion, the drop in oil filter is NAPA 1010StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:These three manuals contain a lot of useful info that hasn't always been so easy to find since Lincoln changed their website early this year.  Save the manuals not just the links those could change again.  Gas engine adjustment, timing, carburetor, governor & R57 idler.http://www.lincolnelectric.com/Asset...OLN3/IM179.pdfR57 idler instructionshttp://www.lincolnelectric.com/Asset...N3/IM179G1.pdfGas engine adjustment, timing, carburetor, governor & electronic idlerhttp://www.lincolnelectric.com/Asset...OLN3/IM277.pdf
Reply:Rad Cap -- Prestone #RSP-28 with lever pressure release. 7lb.  Just fits under the radiator cap cover.  The cover doesn't fit all the way down but it still latches and that is OK because now it is easier to get open without swearing.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Is there any wireing diagrams out there? Or maybe some one knows? I have 2 wires coming out the top of my generator 1 wire goes to the reostat and the other broke off and I cant see from were it came.It was welding good until it came lose, its only long enough to reach the pc board area but i dont think it came from there. I was told its a 90s sa200 but it looks older Ive looked at other sa 200 but they had 4 or 5 wires coming out of there. If that makes sense to any one, any help would be appreciated.
Reply:Will this help?
Don’t pay any attention to meI’m just a hobbyist!
CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST
3 SA-200sVantage 400
Reply:Yes it did help thanks.It went to the second B on the board piggy backed some how couldnt see were it broke must not of been on there very well, its welding nice now just need a fuse. 15 amp i guess.
Reply:I bought an SA-400 in very good condition for $800.  Seems to be welding just fine. Is there any difference between an SA-400 and an SA-200 other than 2 more cylinders and 200 more welding amps?
Reply:Your 400 is bigger and heavier so not everyone has a truck or place to haul one.  The 400 will run larger rods and stand up longer to heavy gouging a 200 was never made to do for extended periods.  Six cylinder engine uses more fuel too.
GMT+8, 2025-12-19 22:23 , Processed in 0.101354 second(s), 18 queries .
