G-213 with a TJD Wisconsin
发表于 2021-9-1 23:12:55 | 显示全部楼层 |阅读模式
Anyone mess with a G-213 welder with a locked up engine? I pretty much have a basket case project, and tearing into this welder has taught me a few things. Being that I have removed the generator housing and the armature, I kinda of run into a problem as far as removing the coupling from the crankshaft because the set screws are not very easy to get to through either of the small round holes, not a good design for repair. I have used a pipe wrench on the hand crank end of the crankshaft being careful not to break it off while using heat and PB blaster on top of the pistons. I'm thinking it could also have spun a bearing and locked it it up to, What does everyone think? Is this thing worth messing with in this condition?SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:Pull the head off so you can see what condition the bores/pistons are in. If there's a lot of rust the bores will probably be pitted bad. Mix a 50/50 of acetone and ATF and pour a quantity in the cylinders and let it soak overnite. Put a pair of curved jaw Visegrips firmly on the crankshaft so you don't do an excess of scarring on it and try rocking it back and forth to see if it will free up. Patience is a virtue for this. keep adding the mix and hope for the best.MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:It's worth digging in to it but Wisconsin parts are expensive. Pull the head off being careful not break the bolts and pour acetone/trans fluid in the cylinders as mentioned. As the acetone evaporates the tranny fluid seeps in.  I don't know about your welder coupling but could you sacrifice it and replace with a lovejoy or make a new one?  I have a TJD spare and a THD.  The THD is on a Lincwelder.
Reply:The cylinders don't look that bad. I'll try the acetone trans mix, hopefully that will do the trick.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:If you don't see any scoring then the problem probably isn't in the cylinders. Hate to say it but it could be a broken rod.MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Yeah, the cylinders don't show any scoring or gouges. I tried removing the cylinders from the pistons off the block the other day, hoping it's just stuck rings and not a broke rod or the bearings are welded to the crank journals. I did try turning the crank with the cylinders a little loose on top of the block and I still can't get any movment, not good.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:Let your favorite penetrating oil solution set in the cylinders for a week or so, the put the biggest piece of wood that will fit on top of a piston and smack it with a hammer, go back and forth from piston to piston.Try some heat also, repeat as necessary, don't give up.  These engines were meant to be rebuilt. Continental sells parts for Wisconsin engines and they have manuals also. Usually parts can be found on the net-eBay etc. Good luck!
Reply:How did the engine lockupIf weather that is easy.But if from no oil it will cost.The engine was used everywhere. The flywheel has #2 morse tapper.It was a great engine and last a long time.Dave
Reply:if u cant move the crank, you ought to be able to unbolt the bottom of the twin barrel, get it to  slide it up.   a tjd is sorta like a vh-4d cut in half.     same barrels/pistons/connec rods.     there were ton of vh-4ds out there on cement mixers etc.   i got a couple laying around, im just terrible about boxing stuff up and sending it off
Reply:Well, I mixed tranny fluid and acetone 50/50 and poured into the cylinders the other day. By the end of this week maybe it will turn loose. The crankshaft is so stiff that when I put lots of force on it, it fells like I could snap the end of the hand crank snout off. I'm going to end up taking the oil pan off and removing the connecting rods from the crank instead of tearing something up. I remember about 20 years ago, the company I worked for had 5 putzmiester concrete pumps with the 4 cylinder wisconsin engine, they were tough!SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:Sounds like the water going into the cylinder is problem.I have used just fill both cylinder diesel fuel and let set for a month in the hot sun.I use this way on few engines and tools. This works with cast iron to cast iron, steel or brassDoes not work with aluminum to cast iron/steel parts. Dave
Reply:You can replace the engine The parts can hard to findDave
Reply:Update: The engine is at a loss. When  I pulled the drain plug, about a quart of water came out.  I had to remove the block from the oil pan/base section, then I removed the rod bearing caps. The crankshaft was in a spot where I had to drive #1 rod stud out, where the rod would clear the camshaft, to remove the cylinder and pistons as a unit. Both pistons are seized in the cylinders with lots of rust, and the pistons are oxidized pretty bad. Even after removing both rods from the crank, the crank was still froze up!!!. This thing is a true bust!!SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:I would just replace the engineDave
Reply:I've looked online, and the ones I see are for different applications,  rebuilt engines are well over $1000.00 which I think is not a bad price, I just don't know if the welder I have is worth it to put that kind of money in it. There are still lots of things that i'm not sure that work on the welding or aux A/C side.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:One thing they're known for is the ones with no fuses for the aux quite often burn up the windings due to overload. The ceramic insulators on the main resistor break and you usually have to cast your own. Have a friend in Florida that had to go thru the insulator thing. IMO I'd write it off as a loss. Hate to see you sink $$ into it and then find bad things on the gennie end. The most I'd do is get the engine apart and assess the damage, those pistons will come out in pieces if need be. MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:It was good welder I own one pass and great.I never would think Wisconsin would not be here.I would look at Harbor freight for new engine.Dave
Reply:Here is a few pics of inside of this engine.
Reply:It look goodThe left cylinder will hard one .But it looks aluminum piston so a torch will take out that piston.Then just and have cylinder rebored. I would get pistons first be for reboring so match the cylinder to piston.Dave
Reply:IIRC the schematic has some resistance values so maybe you can check out the gennie end before putting time and $$ into the engine.MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I'm going to look into generator side and see if the main armature is still good along with field coils, along with everything else. All the wires seem to be in fair condition, not sure if the transformer ok for the A/C side. As far as the engine goes, I'll see if I can get the pistons out of the cylinders without gouging the walls. The crankshaft, cam are going to be another challenge. If it looks like things are going to go south, I'm just going to junk the whole thing, or give it away. It's sad to see something like this that was once a good machine get this far gone.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:Most do know the Wisconsin owned by a aircraft engine manufacturer.So engine was built well comparison to other manufacturersDave
Reply:Sorry it turned out this way.  If never had one of those little Hobarts but always wanted one. Sometimes you get lucky, I bought a barn find 1966 SA200 Redface and in 24 hrs I had it running and welding.  I also bought a late 30’s Westinghouse with a flathead 6 Chrysler that I thought was stuck. Turned out that the armature had slung itself apart, the old Chrysler was pristine inside.  I think if you take your time you can find a running welder like you have for $1000 and have that one for parts.  Just my opinion. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:They this engine on farming equipment and find a replacement on salvage yard.Dave
Anyone mess with a G-213 welder with a locked up engine? I pretty much have a basket case project, and tearing into this welder has taught me a few things. Being that I have removed the generator housing and the armature, I kinda of run into a problem as far as removing the coupling from the crankshaft because the set screws are not very easy to get to through either of the small round holes, not a good design for repair. I have used a pipe wrench on the hand crank end of the crankshaft being careful not to break it off while using heat and PB blaster on top of the pistons. I'm thinking it could also have spun a bearing and locked it it up to, What does everyone think? Is this thing worth messing with in this condition?Just curious,did you buy this welder from a guy down in Miami? I'm also in central florida.I have a Holbart g 213 with the wisconsin engine.Mind is doing ok so far
Reply:cool air, Sorry, opposite end of the country, I bought my welder from the family of the man who started rebuilding it. It was in Anchorage Alaska. I moved to Alaska in 1975 from Pensacola Florida. I sold my welder unfinished to a close friend. We were planning a move to Texas at that time and I wanted to unload some my heavier projects. Good luck with yours.
GMT+8, 2025-12-19 22:05 , Processed in 0.087246 second(s), 18 queries .
