7 way spade trailer plug
发表于 2021-9-1 23:12:29 | 显示全部楼层 |阅读模式
Anyone know of a metal 7 way spade trailer plug? All I can find around here are the cheap plastic ones and they split after less than a year usually along the key or the 1/8" set screw, I'm tired of replacing the cheap POS...............Mike
Reply:Never seen one but you could convert the type used on 18 wheelers with the round pins.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Here you go!https://www.delcity.net/store/7-Way-...RoCxWsQAvD_BwE
Reply:Here you go!
Reply:I wasn't sure they made a metal one with flat pins. I thought I'd  seen way back but I've slept since then, LOL!!Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:You do not want a metal one,, and, you do not want a plastic one,,YOU want a RUBBER one,, I have a rubber one, it has been through most every situation you can imagine,,It just keeps on surviving,, I doubt that you could destroy it with a 2 pound hammer,, unless, you worked at it for a while,,The rubber looks like the same stuff the cord is made out of,, the plug came pre-installed on my dump trailer, I bought it in 1999, and it is still perfect,,
Reply:YOU want a RUBBER one,,
Reply:I will agree the rubberized ones are nice. Only problem is I haven’t found them without replacing the entire cordMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Originally Posted by mrmikey
I looked high and low and never saw a link anywhere for a metal one, I didn't think there was such a beast, tks. Now to find one on Canada :-).
Reply:Seen that, has been ordered. :-)...........Mike
GMT+8, 2025-12-19 22:43 , Processed in 0.096472 second(s), 18 queries .
