There's an online calculator I'm trying to use to figure out the deflection on 1/8" x 1", 1/8" x 1 1/2" and 1/8" x 2" angle iron for various spans. However, it wants to know what the moment of inertia is before it will do the calculation. I have no idea what that is. I looked online to see if there was a way to calculate that but the formulas given were way over my head. Would anyone here know what that moment of inertia is for the sizes I've given
Reply:Try this.. https://amesweb.info/section/second-...alculator.aspxZach
Reply:Be real careful when calculating deflections (and strength) of angles under bending. Depending on the axis you are bending about, lateral restraints, and the placement of the load (relative to the shear center of the angle), an angle will experience lateral-torsional buckling way before it will reach the yield strength of the section.LINCOLNSquare Wave TIG 200Power MIG 210 MPRanger 330 MPXMILLERThunderbolt AC/DCHYPERTHERMPowermax 190CPowermax 45XPHOUGANHMD 130HMD 505FEIN/SLUGGER 14" COLD METAL CHOP SAW 9" COLD METAL HAND-HELD SAW
Reply:JD1
Originally Posted by JD1
. . . I have no idea . . . way over my head . . .
Reply:I always overbuild . Depending on your use, I find people usually excede what it's rated for. Heavy is usually better. Sent from my iPhone using Tapatalk
Reply:Thank you all, except for Opus and his fascination with my a**. The project isn't at a critical level, if it were I'd look deeper into the concerns Ingenuity raised. I think I have the info I need now.
Originally Posted by ronsii
Nice WTXB
According to that the values are:1 inch = .0221.5 inch = .0782 inch = .19And the deflection calculator says a 10 foot length of 1 inch angle with a 200 pound load in the center will deflect 10.9 inches
I assume that if that 200 lb load was supported with not one piece but two, like for a shelf, then the deflection would be half of that - 5.45" instead of 10.9"?
Reply:Thanks ronsii, if the project goes through the angles will be bolted on each end so that helps. Specs are changing so I'm not sure it will go through but at least I know how to deal with it now.
Nice WTXB
Originally Posted by William McCormick
I highly doubt a 1" steel angle ten feet long is going to support 200 pounds at the center. Unless you anchor the ends and use it taunt like a piano wire. Sincerely, William McCormick
LOL!!! Yes, I just always like to put extreme values into calculators to see what the results come in at
Originally Posted by OPUS FERRO
JD1Agree - you don't know - whether your posterior'is punched or drilled' . . . PLS - describe your entire project, so the details can be properly eviscerated . . .hthOpus.
Reply:Thank you Dave. I did comment about Opus in post 7, he's quite a challenge.
Reply:Just for info relative to this thread, is angle stronger with "leg up' or "leg down" or is there any difference?Hobart 190 migLincoln/Century 140 migLincoln buzz boxChicago Electric cutoff sawLotos LTP5000D Plasma CutterHMC Swivel head band saw
Originally Posted by Oscar
depends how it is suspended at the ends and depends on how exactly you plan to load it.
Originally Posted by MinnesotaDave
The orientation doesn't change the moment of inertia (if I recall correctly).Leg up or down is the same "strength" as long as everything else is the same (support from twisting and load applied).Diagonal orientation is weaker though.
Reply:Moment of inertia relates to bending, not to strength in the pure sense. Sure if you have a long piece of angle it will "fail" with a relatively small weight on it and even distort/buckle from it's own weight if long enough, but moment of inertia is not used in basic strength calculations. When you pull on a short section of angle it is definitely easier to bend in one direction vs the other.Tweco Fabricator 211iSieg X2 AMT radial arm drill pressAMT belt/disk sanderHF 4X6 bandsaw
Reply:The moment of inertia, I (more correctly termed the 2nd moment of area, for structural engineering) is an important structural property for ALL structural sections - for both stiffness (deflections) AND strength. For strength, the dominant structural property is section modulus (S for elastic section modulus) which is the moment of inertia divided by the distance from the section centroid to the extreme tip of the section (top and/or bottom), so S=I/y; and y is: ytop or ybot, depending on which way the section if orientated, and the stress you are looking at.The flexural strength of single angles is complicated. There has been several PhD dissertations and many research papers on the general subject.Depending on the orientation of the legs and the location of the load application (relative to the sections shear center), they suffer from local buckling (if ratio of the leg LENGTH to leg THICKNESS is too large), and lateral-torsional buckling if the tip of the leg is in compression and there is not adequate lateral restraints (like attachment to adjacent stiff members at close centers).The centroid and shear center of angles do not coincide. Any load NOT applied through the shear center will cause torsion to the section.Equal leg angles only have 1 axis of symmetry, and unequal legs have no axis of symmetry. So flexure about a X or Y geometric axis often needs to be resolved in the principal axis - the axis where the section has the maximum moment of inertia. An axis of symmetry is also a principal axis.Structural angles fare better under axial loads, especially tension - hence why you often see diagonal bracing using angles.If you have to use angles in flexure, double them up (back-to-back) and form a T section.LINCOLNSquare Wave TIG 200Power MIG 210 MPRanger 330 MPXMILLERThunderbolt AC/DCHYPERTHERMPowermax 190CPowermax 45XPHOUGANHMD 130HMD 505FEIN/SLUGGER 14" COLD METAL CHOP SAW 9" COLD METAL HAND-HELD SAW
Originally Posted by M J D
I don't know about that equal force thing. On a bender it takes less force and gives you a better bend when pulling on the web vs pushing it, probably even more so with channel. I realize that that is a controlled bend and not just a force to failure thing but it stands to reason. |
