Operation: Pole barn/shop
发表于 2021-9-1 23:12:06 | 显示全部楼层 |阅读模式
Starting my own thread on my pole barn/shop. Mind you before one thinks just rent this to do this or contract this out for this or call in a cement truck it’s not happening out here due to topography, distance from town, limited resources in town, time constraints and I live off grid. No running water here, power from solar or genset when welding and living in a truck camper doing this. Temperatures have swung from -40 to 112 degrees. Mail doesn’t even run here but 3 days a week if that.This is my first build on this magnitude of size of project and I’m open for suggestions, facts and opinions. The build will be 43’ wide 32’ deep and is built from parameters of the materials on hand I got for free, only cost me hotel fees, diesel and time. Going to be a monitor type barn/shop built from drill stem/pipe for the framing 4.5” for main atrium, 2.875” for the side wings, and using galvanized 20 gauge grain bin tin from 18’ diameter bins for the roof/side walls and regular 26 gauge galvanized sheets for front and back walls.The ground is not flat here and is so steep I can’t even turn a semi with a 48’ trailer around without scraping, high centering or just getting stuck, need a 6x6 out here.First up is digging a flat spot, no flat spots on top of hills and no hills in right spot on proximation for layout, blocking northern winds, ability to drive up, distance from the road, distance from where house will be built and direction I need to face the structure so digging into a hill it is.
Reply:Here is the pads the poles will be welded to. Took salt lick tubs mixed (3) 60 lbs of concrete in it, dropped two layers of remesh to get 2 x 2 which gives me 6 inch by 22 inch reinforced pad to weld the poles to, I sunk custom made plates from 6 inch channel iron with rebar legs welded on to to anchor in the concrete also. After I set them in the trench I cut a slit on the tubs to drain water from the pads. These will be for the main atrium only the side wings will get smaller pads to sit on.
Reply:After those dried for 30 days not of my doing to wait that long but works out to cure the concrete it was time to weld the poles on. Mind you these are welded on to prevent pole from slipping off the pad and I can’t hold a 20 plus feet pole weighing in at 11.6# per foot pipe as I brace it by myself. Used the I beam as a way to make the pole sit perpendicular to the concrete pad to weld to for a perfect 90 degree fitting, also when I welded the pipe to the channel I left a quarter inch unwelded so any condensation or moisture can drain out the bottom of the pipe.
Reply:You are an army of 1Looks good. Be careful.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Up we go!
Originally Posted by _Weldman_
Thanks, it’s funny you say that I am combat vet, ex infantry. Wife helps where she can too but for most part I try to keep her out of harms way.
Reply:A pole barn is great 👍for a weld shop. 1,200 sqft is good size too. A good evaporator cooler on wheels 😎 will keep cool. For heat a good generator keep warm and low in cost.Dave
Originally Posted by milomilo
Nice looking land. What state are you in?
Originally Posted by smithdoor
A pole barn is great for a weld shop. 1,200 sqft is good size too. A good evaporator cooler on wheels  will keep cool. For heat a good generator keep warm and low in cost.Dave
Thanks, I’m about 340 miles north of you in Montana over near Colstrip. We love it so much after buying 30 acres we bought another 40, hopefully buy all the neighborhood around this piece to prevent anyone moving in next door. Don’t mind neighbors I do mind trailer trash dumping a trailer on the property then trashing the place and leaving in few years cause they can’t hack it here. I can count 5 places as such and one where someone thought they could build a Earthship with shovels some tires and all you can drink beer on the north side of a ridge that blocks the southern winter sun, phucking morons.
Reply:what a bunch of work.      i met a const/job supervisor, and got to be friendly - we stay in contact.       he builds his shop first, then lives in it for a couple/few  yrs while he builds his  a very well built house, which   he lives it till the time/market is right, then he sells, and starts over.    his wife is a real estate agent, so the two make a food team.      he's in his 3rd or 4th house now, which will be his last.     ur case, sounds like this is where u wanna stay, besides, the gov is compfortable w/ trained combative survival skilled x military  living off grid in secluded wooded  areas.      i remeber u takin the material down.    lookin at it, i thought might have way walls.    i guess ill have to wait and see.Last edited by 123weld; 2 Days Ago at 09:06 PM.
Reply:My last shop was a pole barn 20ft x 80ft. Did have 3 sides the other side was open so could be used for larger projects.  I live California most of year the days are sunny. The machine shop was in different building insulation for year around uses. Dave
Reply:Forgot to add, the height on the main opening will be 15’ give or take few inches and the roof will peak out to 24’ give or take a inch all based on how much rock I put down. Have a rock quarry within a mile I can drive my backhoe to and walk back and get my grain truck to load up for the price of straightening the owner’s property out which I’m the only one with access to it. He doesn’t live there but I can come and go as I please and he doesn’t care. It’s the same rock I put in the trenches below the poles.I will put a slab down in the main atrium only also later on after the side wings are done which those will get just rock, be a nice 19’ x 32’ slab.
Reply:I didn't see this when you started the thread.  Absolutely excellent!!!!!!!!!!!!!!!!!!!The attached footings are a very good idea.  It would be hard to plumb that stuff by yourself.  Excellent!!!!!!!!!!!!!!!!  That's thinking outside the box.I don't know where your water table is, or whether water might percolate down through your backfill, but generally any time we put pipe below grade we make certain to do our best to seal the bottom.  Water can come in through the bottom, and fill the pipe.  Generally, not having to face your situation with mile long pipe, we just embed the lower part of the pipe in 8 sack concrete mix (waterproof).  I'm not sure I'd leave any part of the base, where it meets the pad, unwelded.  It will let water in.
Reply:Water can always find it's way into things. Make sure you cut some holes or leave the bottom of the footing open somehow. You could stick a short piece of PVC thru the footing pad to insure drainage
Reply:I guess my thinkin' is way out of line
  We average 23" per year, in a normal year............this year it's been closer to 30" I think.  Been a muddy mess, and it actually rained again today.
Reply:Was getting building permits pretty straightforward?ChrisAuction Addict
This is how the structure will look like using the grain bin pieces as walls too.
Reply:Looks great but for weld shop clear span works the best as you never know the type of work you doing tomorrow. Dave
Originally Posted by John Baptist
Amazing design !!!!
Reply:Now they are plumbed straight for most part I need to backfill 75% of the hole and pack it in so I can fine tune the last bit when I put a header up. This is what I welded up to go on the backhoe bucket to pack the dirt in from scraps, 6 inch channel welded to 8 inch I beam.
Reply:There is free/low cost materials keeping the cost down. The one item that I found is a monorail hoist 2 to 5 tons. If forklift dies on bad day just use the electric hoist. Or some cases need 5 tons and forklift is 2 ton.If you have employees the monorail saves money. Take Guest out for employees.  Dave
From outside pole to outside pole on the main atrium is 19’ I am limited to the constraints of the radius from the roofing materials. The grain bins had 9 sheets per a ring for 18’ diameter take half of that and you end up with four and half sheets which would be odd at least to me. So I made it even 5 which means I can stretch it out to 24’ maximum before metal starts kinking, which gives me a choice to provide a cap over the side walls/roof where they meet at the top. About the same with the side walls/roof except those were 6 sheets a ring for 18’ that can also be stretched out to 24’ so with 4 sheets I can get a 12’ span. That was a rough draft drawing I have posted for an idea of what it will look like more details will come up as I build more to be seen.
Reply:I have a 9spd, and really don't like it.  I'm used to having those extra 4 gears.
Reply:Defendant for my state.HERE is a Excel work sheet for most work.Note column calculation may need three different formula.Very helpful but still use a engineer as a but cover.please post anywhere to help other .Dave
I’m only licensed to 55k on farmers tags as that’s the max till I need paperwork besides a CDL, insurance, registration and a MEC to move the rig, so I don’t need to row gears since I’m not 80k.
Reply:Looks like your neighbor just south has a pretty nice water impoundment. Is it lined? We have tin pole barns all over around here on the old coal strippins, they level a spot with a D9 drill 5' holes on 10' centers with a shot rig drop in 2"x30' drill steel in the holes. There are some pretty interesting ones that evolved over time with offices and break rooms. Scale shacks all wall papered with nude women.
GMT+8, 2025-12-19 22:40 , Processed in 0.075761 second(s), 18 queries .
