Cigweld cutskill 60 amp plasma cutter
发表于 2021-9-1 23:12:03 | 显示全部楼层 |阅读模式
Could not find any videos reviews or anything on the Cigweld 60 amp single phase plasma cutter, so I recommended a friend who was looking for a plasma cutter to buy one.  Then I tried it out and bought my own I was that impressed.Here is a short video I made of it severing 40mm thick steel out of a 60 amp single phase machine.
Reply:Cut Skill is the name Esab uses for lower end products or products made overseas. Wonder if Cigweld sources them from Esab's parent company? One of things to look at with plasma torches is consumable life and availability.
Reply:Where did you buy the machine?   Seems  Like they are only available in  Australia. Not too  many  60 amp  machines  will cut  40mm?
Reply:Did you really you recommend your buddy buy a certain plasma cutter so you could try it  ?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Originally Posted by Woznme
I'll see if I can get the facts right going from long term memory.It [CigWeld] also changed hands a couple times, Victor, Thermodyne, before being acquired by Esab.
GMT+8, 2025-12-19 22:40 , Processed in 0.071341 second(s), 18 queries .
