4 1/2 grinder uses.
发表于 2021-9-1 23:12:02 | 显示全部楼层 |阅读模式
Found a new use for an angle grinder!
Reply:Oh yeah, Don't try this at home.
Reply:Chain seems to be spinning fairly fast... wonder how the speeds compare?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Chain is dangerously loose.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Most of his tacks are suspect! Barely, if at all fused on one side. That could be pretty scary if something let go.
Reply:Terrible idea in my opinion...Special award for the locked-on switch so that if anything bad happens it stays running wide open...Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice loose chain. One nail in one piece of wood and I wonder where that chain will wrap around...
Reply:Darwin's Theory about to be applied to the operator of that fab disaster.....
Reply:I think you can buy a new electric at HoDe for less than the investment in this Darwin saw.
Reply:After seeing him stick and wire weld, I wonder if he thinks that is the correct way to weld every thing.
Reply:I don’t think I’ll ever need to turn a grinder into a chainsaw.Only good use I’ve ever had for an electric chainsaw was cutting up dunnage for rigging/ moving projects in a mill.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:They'd work pretty good for cutting a carcass in half if you could get a fine enough chain. I didn't like the bone fragments it left in the pork chops so I went back to the recip saw.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:The chainsaw disc for grinders is scary enough.  I really could use one to remove bark from slabs and projects, but arthritis has weakened my grip.  Have had the grinder with just a regular grinding wheel come out of my hands a time or two.   Will stay away from anything with blades on a grinder.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Pretty sure that 4 1/2 " grinder runs 3000-4000 rpms faster than a 2 stroke chainsaw, that alone is unsafe, then factor in the loose chain. But hey, at least he had an automatic oiler! I think he should incorporate some buckin' teeth into that chain gaurd.Last edited by CAVEMANN; 07-10-2021 at 02:40 PM.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Originally Posted by mrmikey
Watch at 8:02 of this video, not much makes me cringe but this did,  .
Watch at 8:02 of this video, not much makes me cringe but this did,  . If you want to hear him describe it  even tho it is a serious injury, he describes it in an entertaining if not macabre way and take full ownership of the way it happened.........Mike
Reply:....but I completely disagree with his assessment of the cause of the accident. He should have repositioned his workpiece so that an unexpected catch or jump of the tool would not place his body in the line of fire.
Originally Posted by txpitdog
He should have repositioned his workpiece so that an unexpected catch or jump of the tool would not place his body in the line of fire.  .
Reply:my dad used to scold me as a child for leaving planes like that.....
GMT+8, 2025-12-19 22:40 , Processed in 0.071516 second(s), 18 queries .
