What’s this tool?
发表于 2021-9-1 23:11:58 | 显示全部楼层 |阅读模式
Anyone know what this tool does?(Metal piece, not soldering gun in box)Knurled cap screws on and appears to adjust length.Has “6515 Plumb” stamped into it.Edit: actually,I think it says Plomb
Last edited by jpump5; 07-04-2021 at 10:10 PM.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Pretty sure it's a wrist pin tool.  For what make and model engine I couldn't tell you.Yeswelder MIG-205DS(3) Angle Grinders at the ReadyJust a hobbyist trying to improve
Reply:It's old. Plomb started marking their tools Proto following a 1946 trademark dispute with Fayette R. Plumb, Inc., that made hammers and. punches.http://alloy-artifacts.org/plomb-tool.html
Reply:If you look at the link that Forhire posted under specialty tools, there is a similar wrist pin tool pictured there with a different top. Check out the numbers and that should give you an indication of date. Sounds like they were for Ford Model A and B engines.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Yup, wrist pin tool.Thanks guysMiller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:It looks like a alignment tool for clutch if diameter is 0.66" [17mm].Dave
GMT+8, 2025-12-19 22:41 , Processed in 0.093100 second(s), 18 queries .
