Welding Fixture Table
发表于 2021-9-1 23:11:55 | 显示全部楼层 |阅读模式
I had been planning on building a new welding table for quite some time. I had a pretty good idea of how it should be but was (as usual) struggling somewhat with logistics. Since discovering the  thread started by Rustyshackleford (Brett) I have been working with John from Texas Metal Works on a custom table with some unique features. I’m usually the type to build things myself but in this case.....My cost for locally laser cutting the pieces alone would have been considerably more than my entire purchase price having John build it. It has been a several month process incorporating my ideas into a buildable product from a manufacturing standpoint and John has been very patient with me. Hopefully my input will result in future welding table options/upgrades available from Texas Metal Works. Here are a few random photos taken during construction.  The table size without extensions is 40” x 80” with a 1/4” table top braced from the underside to achieve and maintain flatness. A photo of underside. Note the 2inch square holes at each corner of the table. These line up with the oversized 3” square tube legs I specified to accommodate the 2.5” receiver tubing for four vertical receivers.
Bolt on plates with custom slots to accommodate vertical receivers ...
Heavy 11 gauge center mounted drawer with industrial slides ...
To be continued.......
Sent from my iPad using Tapatalk
Reply:Nice little table Sent from my SM-G960U using TapatalkI haven't built anything I can't throw away.  Perfection is the journey.    Mac
Reply:Well if it needs to rest for a couple years, I can give you my addy.Sent from my SM-G960U using TapatalkI haven't built anything I can't throw away.  Perfection is the journey.    Mac
Reply:It is a long trip. HeHeSent from my SM-G960U using TapatalkI haven't built anything I can't throw away.  Perfection is the journey.    Mac
Reply:This is a pic of my welding table base (sitting on a welding table). I opted to delete the casters and add cross bracing to accommodate moving the table with a pallet jack.  Adjustable height swivel pads will replace the casters and allow for levelling the table. The lower bracing also allowed for extra storage area.  Initially I planned on two powder coated MDF panels mounted flush with the crossmembers so stuff could slide out easily but John from Texas Metals suggested black HDPE panels which dropped right in the cross bracing.  No painting necessary or dealing with inevitable scratching. Plus totally moisture resistant.
I had John laser cut and pedestal mount an intermediate shelf for storing sh*t but mainly for interest and aesthetics.  Even had matching holes cut (but a few thou in diameter larger to allow for the paint).
View from the underside of intermediate shelf showing streamlined gussets for the suspended pedestal look.
And here’s a pic of the base with its special BLUE multi-coat powder process....
Reply:Wow... that's going to look bright, even in your shop where there's a lot of shiny and bright. Sweeet...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Are you up for sharing cost prior to shipping?Looks great!Miller Syncrowave 180SD
Reply:I’ve been looking at the 28mm tables from Build Pro and Seigmond. Interested in other options.Miller Syncrowave 180SD
Reply:I wanted mine nitrided but apparently no one in North America has tanks big enough. Most are done in Europe and Asia.  Sent from my iPhone using Tapatalk:
Originally Posted by Lis2323
This is a pic of my welding table base (sitting on a welding table). I opted to delete the casters and add cross bracing to accommodate moving the table with a pallet jack.  Adjustable height swivel pads will replace the casters and allow for levelling the table. The lower bracing also allowed for extra storage area.  Initially I planned on two powder coated MDF panels mounted flush with the crossmembers so stuff could slide out easily but John from Texas Metals suggested black HDPE panels which dropped right in the cross bracing.  No painting necessary or dealing with inevitable scratching. Plus And here’s a pic of the base with its special BLUE multi-coat powder process....
Reply:GAWD THAT'S NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by psacustomcreations
It took a couple of seconds trying to figure this sentence out. .
Originally Posted by ronsii
It's BEAUTIFUL!!!!!!!
Reply:Amazing
Originally Posted by whtbaron
And I thought you were going to whine about the COLOUR (color) looking more purple than Miller blue....
Reply:Really amazing and I can't wait to see it in place, nestled comfortably amongst all your other goodies.I keep saying I'm going to rent a mag drill so I can make some holes in my bench.  Gotta clean it first, though.
Reply:That is a work of art Lis!  Actually, from the photos you’ve posted your whole shop is a work of art!  I’ve tried to keep a neat shop but usually after a full day I’m so worn out and sore the last thing I want to do is sweep up the shop.Miller 350 DynastyMiller TrailblazerMiller 625 Plasma Lincoln Power MIGVictor oxy/acetyleneHyperthem 85
Don’t you find it amusing how we deliberately misspell words so that we don’t look like high school dunces to our American friends?
Reply:Lis2323Your ears burning? I was at my LWS and a local company makes fixture tables. The sales man saw me standing there and put the press on. Damn they are neat
Reply:My LSW is pretty nice.Still no plan on a table. I'm going to look at the those down the road I told you about. I do have this plan, no more gym equipment or I'm going to charge what I should charge. If they walk they walk. I try and stay under "Rogues fitness" price  but  I can not compete with a robot. If I lose work fine, I can work on the old car, do art and furniture. If I do art and furniture I'm  will drop insurance. Plus the "maker space looks like its going to happen. I sold $22,000 worth of gym equipment but really did not net enough to amount to much. RANT OVER lol. I may send a PM about the art furniture world.
Reply:Looks great
Reply:Great looking table!Lincoln 350MPMillermatic 350PSyncrowave 2501969 SA200HTP Invertig 221
Reply:Looks really really good!!!!
Reply:How much for the couch with the cowgirl?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Never know until you go for the test drive...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I like the wheels/chocks on the bottom set.... I've been thinking about something like that to keep my bandsaw in place. But on the couch? Oh man.... I can see a million stubbed toes and several new words in the dictionary over that one. Looks nice though...he needed to narrow up the axle and protect it with a coffee shelf like the table.Last edited by whtbaron; 01-14-2021 at 01:45 PM.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Or let the cowgirl sit there....Sent from my iPad using Tapatalk
Reply:Like the used bicycle seat sale, I think the price just went up again...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:My table was shipped last Friday. Pics of it wrapped for the long journeyPowder coated frame wrapped and entire assembly strapped to custom built pallet.
Tabletop wrapped
Reply:NICE!!!!!!!!!!!! 40x80?
Reply:Sweet.... I guess it will be occupying the spot vacated by the rotary table?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Well... I just moved the dining room table out so it will have a place of honor... momma might not be happy but meh. I heard that table was going to be to tired to make it all the way there in one leg....Sent from my SM-G960U using TapatalkI haven't built anything I can't throw away.  Perfection is the journey.    Mac
Reply:I have to look at the extensions. I missed that detail
Reply:Cool!!!!   I really like the table... but the pallet brand is impressive too
Reply:Typical Texans
Reply:No table rustlers allowed...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Table rustlers?? I am just wondering how long before it suffers the same fate as the rotary table...so I can plan a trip north to pick it up.Mike
GMT+8, 2025-12-19 22:41 , Processed in 0.103704 second(s), 18 queries .
