Tig Scratch Arc Question.
发表于 2021-9-1 23:11:54 | 显示全部楼层 |阅读模式
I have a Thermal Arc 95S tig welder that is "live" all the time. Is there a pedal that acts as a switch to turn the power to the electrode off?Last edited by rahtreelimbs; 3 Days Ago at 10:17 PM.
Reply:Is the 95S a stick/lift-arc machine with aswitch to choose between lift arc tig or stick?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Originally Posted by SquirmyPug
   With some practice you can kill the arc at the end of a weld without to many issues.   You can rock the cup back and "snap" out of the weld to kill the arc then get shielding back over the weld (the crater may need to be cleaned up a little).    If you have room at the end of the weld you can increase travel speed until you see the puddle "dry up" then snap out like the first way I listed.
Originally Posted by 123weld
u described that pretty good.        i thought i remeber  being  just a pup from e. bay calif. , am i right?      if so, how did u get all the way over there
Reply:rahtreelimbs, I looked at the Thermal Arc. Nice 110 volt rig. doesn't look like it has a switch for 2t 4t?  What I would do and as a habit , disconnect your ground or work lead whenever your not welding. That will prevent unwanted arcs. Hey squirmy,  is that what you call fishing in Jacksonville. If I remember, you were dragging them sharks out of the water bare handed by the tail. No?
Basically.. but I put a tail rope on the bigger fish
   It's all rod and reel to get it close enough for the rope though
GMT+8, 2025-12-19 22:39 , Processed in 0.097364 second(s), 18 queries .
