Outdoor wood fired boiler
发表于 2021-9-1 23:11:32 | 显示全部楼层 |阅读模式
Hello, Has anyone built their own wood fired boiler for in floor heating in a garage? If so I am looking for ideas  build and anything you would change if you were to do it over again. I am looking at heating a 40x60 shop with 6" of concrete. Would really like some feedback and thanks in advance.
Reply:I built mine after copying a Shaver stove made in Arkansas. I made it take 250 gallons of water. More water smoother recovery. I installed a coil of copper tubing that my potable water runs through with a check valve and heat my hot water with it too. Never run out of hot water. Also hooked in line is a ball valve hooked to an over flow so that I can add water to the stove. JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-19 23:41 , Processed in 0.110758 second(s), 18 queries .
