Flashback
发表于 2021-9-1 23:11:31 | 显示全部楼层 |阅读模式
Here is a link that was provided by a member about Flashback.http://www.toolboxtopics.com/Gen%20I...0Flashback.htmIt happened to me so I thought it's best to make this a stickey..Thank you jbmprods for the link!...zap!
I am not completely insane..Some parts are missing
Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:your welcome Zap and glad it was just a wake up call. good idea you have hear to. lots of folks will see it.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:A good combination is to have flashback arrestors at the regulators and check valves at the torch end.  The check valves are nice because they don't add a lot of bulk at the torch end.
And these are the arrestors.
Reply:When you inspect torches, keep an eye out for indications of internal fire damage such as heat discoloration.This now-much-shorter Victor mixer left parts of itself in the tube when it melted. I guess the Smith and Airco designers have a point. Tip-mix torches don't do this:
Reply:good post...this is good to know...i always lite my torch with mixed gas so it does have all the black smoke.
Reply:I would recommend investing in a newer torch with built-in flashback arrestors and reverse flow check valves.  It is too easy to get in a hurry and not take the time to put these in the line to the regulators separately.Ranger 225Weld Pac 100Power Mig 180CMagnum 100 Spool GunHobart EZ Tig 165i
Surf for cardiovascular exercise.  Saltwater is good for you.
Reply:under what circumstances would anyone use acetylene over 15lbs? i find 10 lbs works fine for everything from sheet metal to 3" plate by changing the cutting tip to the correct size.
Reply:This one provides an excellent visual of what takes place during those undesireable conditions.[ame]http://www.youtube.com/watch?v=xwOkUxe8Xy8&list=PL47639173BE8AF3F8&featur  e=player_embedded[/ame]Last edited by DSW; 10-21-2013 at 05:20 PM.Reason: Fixed bad link.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Just reposted it Steve.  Someone else did awhile back and I think the entire video series on proper setup and use should be a must watch for newbe OA torch users as well as a refresher for seasoned operators.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Great thread with great info!.. The YouTube was nice too! Showing what can happen during a "flashback''!How many on here have the flashback arrestors on their O&A setup ?Thanks!Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:I was thinking of putting flashback  arrestors on my Victor  med. duty torch handle but the 3/8 sizxe seems nonexistent.Maybe I am missing them but all seem to be 9/16.Doing the best I can with what I got
Reply:Thanks to the member that originally provided Zapster with the link that started this thread.Way too many guys using torch rigs and don't know how close to a (catastrophic) failure they are at.How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
GMT+8, 2025-12-19 23:51 , Processed in 0.078452 second(s), 18 queries .
