Hi all, I am currently in the process of getting a replacement bottle of my usual gas mix and the LWS guy said he can't get anymore of it which i thought that was odd as it is a popular tri-mix gas, (maybe he didn't want to stock that one anymore),
any way, this left me with no option but to research for a different mixture that would be suitable. As my welding covers thick to thin plate mild steel, I wanted a sort of general one gas mix which would cover as as many welding situations (plate thickness wise) as possible without having to get multiple different gas mixes. Over here in Oz we can't buy the big bottles outright and can only rent them, which works out quite expensive. Whilst doing the search on the different types of mixes from the various manufacturers I came across this excellent article by BOC on the various different gasses and the effects that different gasses and mixtures have on the welds, both in TIG and MIG with the welds done buy a robot so no human intervention or error to cloud the results. It explains their gasses and has pictures of the welds, the various penetrations and using different metals.Once you find out the composition of the gas mix which suits your requirements you could track down an equivalent from any supplier. This document would be of benefit to all those members who ask about welding gasses, ie; Why can't I use straight argon for mild steel????? etc.Anyway I thought it was a very good informative read, I also found a supplier who has that gas mix that I wanted and was cheaper by about 30% and would deliver and exchange bottles for free.
So in the morning I will be switching my supplier.
It's a 1.5mb download and the download link is: https://boc.com.au/boc_sp/downloads/...re_AUS_v12.pdfMiller Auto Invision 456 + S-62 wire feederC6240B1 Gap bed lathe16 ft3 air compressor16 speed pedestal drillHafco BS-912 Bandsaw
Reply:Thanks mateShould be a StickyEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Originally Posted by Broccoli1
Should be a Sticky
Reply:Suggestion to also see:http://www.esabna.com/EUWeb/MIG_handbook/592mig1_1.htmand especiallyhttp://www.esabna.com/EUWeb/MIG_handbook/592mig4_1.htmAnother overview from Lincoln about GMAW, including shielding gases:http://content.lincolnelectric.com/p...ture/c4200.pdf The best laid schemes ... Gang oft agley ...
Reply:Thanks ZTFab for that quick response to make it a sticky. Some of us old newbies like that informative stuff.
Nctox, Stickmate LX 235AC/160DC HH210
Reply:Here's another good one for shielding gas selection including some general info about GMAW and filler wire as well.GMAW welding gases and info.pdfhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:You can indeed buy the bottles outright (at least in Sydney). I have.http://www.speedgas.com.au/home.html__________________________________________________ _I could not care less where anything is made. I don't fall for the myth that locally made is 'better'. If I think something is good value for ME, I'll buy it. That said, I do like European quality
Reply:I guess you could get by with one gas but I can't imagine only one gas in my shop...It would make things VERY difficult and at best compromise quality......
Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Anyone dealt with Matheson TriGas? Specifically their APN-7 mix that is targeted at replacing argon/helium mixture for alumium TIG welding?This is what my Matheson Rep/Sales person gave me:http://www.mathesongas.com/industria...SON-Select.pdfand here is a slideshow that they gave me in print:http://www.slideshare.net/mathesonga...n-welding?ref=They can only get it in the large 300+ ft³ tanks, but I was hoping to get some input on it if anyone has used it.Last edited by Oscar; 06-19-2012 at 03:22 PM.
Reply:No, I have not heard of it. It makes me wonder though.....in college we were taught that we needed to shield the weldment from our atmosphere. Well, our atmosphere is mostly nitrogen, and about 21%oxygen. Why would you dope shielding gas with nitrogen? It is already in the air.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Indeed you are very right that we are required to protect the weldments from atmospheric gasese and it sounds hilarious to shield it with nitrigen when it is already present in air.
Reply:A three-year research program focused on the application of advanced processes for P92 pipe welding was started in March 2011.The research program include the production of P92 pipe welds with the narrow-gap TIG (NG TIG), TOPTIG, variable-polarity submerged-arc (VP SAW), flux-cored (FCAW) and electron beam (EB) welding processes. NDT/mechanical testing of the narrow-gap TIG has been recently completed with successful results. Following these, creep testing is planned to determine their high-temperature properties.Process parameters to be applied when welding P92. The following were selected:Single-pass layer TIG welding techniqueNarrow groove joint 9mm wide with a 2° slope, accounting for cross seam shrinkage, enabling the maintenance of a constant groove width after each welding passThe use of pure argon welding gas, known for its universal availability
Reply:From where can I buy the welding gas..!what instruments are necessary to use it...?http://www.plagiarism-checker.me/
Reply:The reference to BOC gases is no longer valid. Anyone know the new url for this information?
Reply:http://www.coregas.com/images/pdfs/s...on%20chart.pdfThen search their safety data sheets for the mixes of the gaseshttp://msds.chemalert.com/default.aspx e.g. search for CoreGas to bring up all the CoreGas products, ShieldPro for those etc.
Reply:I think this is it? Haven't looked at it yet but looks like a similar name....https://www.google.ca/url?sa=t&sourc...6Ovro4zqfBb0VQ
Reply:That's a good one!
Reply:Does anyone have the PDF from the link that Ed posted originally?Old Welders (at work)Miller Deltaweld 452Miller Syncrowave 250Lincoln 180c powermig Current Welders (at work)Millermatic 252Millermatic 350 Miller Syncrowave 250DXMy Welders CE Dual Mig 170CE Inverter Arc/Tig
Reply:Thanks Sedly...that worked!
You were right though....definitely slow to load!Old Welders (at work)Miller Deltaweld 452Miller Syncrowave 250Lincoln 180c powermig Current Welders (at work)Millermatic 252Millermatic 350 Miller Syncrowave 250DXMy Welders CE Dual Mig 170CE Inverter Arc/Tig
Reply:Hi Joker11, That's actually a good point, I never thought about why do we need shielding gas since the atmosphere consists of primarily Nitrogen....until I read your post that is. The reason shielding gas is required is to protect the weld from Oxygen and water vapor. It is the Oxygen and water vapor that compromise the welds. Now given that, I guess if one was to weld in space, there would be no need for shielding gas, but there would definitely be a cooling problem of welds due to extreme low temps. Bottoms up.A plumber is an adventurer who traces leaky pipes to their sourceChilliwack Plumbing and Hot Water Tanks
Reply:RobmanQ, if you wanted to TIG in space, you would still need a knoble (ion) gas for the plasma to melt metals. Ive never welded in space but Im thinking stick or flux core would be the method or some new type of arc. It wouldnt be practical to take Argon or Helium into space at the present time. Maybee in the future they will have semi shuttles tho. I have a question: has Neon , Xenon or any of the other knoble gases been tried for TIG or MIG ?
Originally Posted by Insaneride
RobmanQ, if you wanted to TIG in space, you would still need a knoble (ion) gas for the plasma to melt metals. Ive never welded in space but Im thinking stick or flux core would be the method or some new type of arc. It wouldnt be practical to take Argon or Helium into space at the present time. Maybee in the future they will have semi shuttles tho. I have a question: has Neon , Xenon or any of the other knoble gases been tried for TIG or MIG ?Ok thanks HT2. My spelling has gotten worse in recent years. I still have to ask tho; why isnt Neon a popular weld gas? Xenon, Krypton and Radon are also Noble.BTW, altho Nitrogen isnt noble, it will ionize and melt metal. It has been mentioned that Nitrogen is not good for the weld tho. The Noble gases wont react like nitrogen or oxygen with metal because there valence band is full.Last edited by Insaneride; 01-14-2017 at 10:56 AM.
Reply:I never looked much my self but I have heard that neon is something like 100x the price of argon.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Heres some ion energies I had saved. Ionization Energies (eV) of Atoms and IonsPrepared for IAU Symposium 210 (Uppsala Sweden, June 2002)Values for first and second spectra are from NIST (II's courtesy of Jean Sansonetti), except for At I, from HCP. Most other entries are from Handbook of Chemistry and Physics, 3rd electronic edition. Additional entries are from Dappen (AQ IV, 2000) or Cowan (1987). Most of the Dappen values are given to the nearest electron volt, though In IV, Tl IV, and At I are given to the tenth of an eV. Some entries for the REE third and fourth spectra were given by Cowan to the hundredth of an eV, and those values are reproduced here, though they are surely uncertain. It is amazing that we know the second ionization energies of several 5d elements only to the nearest eV. Y II is from Phys. Scr. 44, 226 (1991).Hydrogen H 1 13.5984Helium He 2 24.5874 54.417760Lithium Li 3 5.3917 75.6400 122.45429Beryllium Be 4 9.3227 18.21114 153.89661 217.71865Boron B 5 8.2980 25.1548 37.93064 259.37521 340.22580Carbon C 6 11.2603 24.3833 47.8878 64.4939 392.087Nitrogen N 7 14.5341 29.6013 47.44924 77.4735 97.8902Oxygen O 8 13.6181 35.1211 54.9355 77.41353 113.8990Fluorine F 9 17.4228 34.9708 62.7084 87.1398 114.2428Neon Ne 10 21.5646 40.96296 63.45 97.12 126.21Sodium Na 11 5.1391 47.2864 71.6200 98.91 138.40Magnesium Mg 12 7.6462 15.03527 80.1437 109.2655 141.27Aluminum Al 13 5.9858 18.82855 28.44765 119.992 153.825Silicon Si 14 8.1517 16.34584 33.49302 45.14181 166.767Phosphorus P 15 10.4867 19.7695 30.2027 51.4439 65.0251Sulfur S 16 10.3600 23.33788 34.79 47.222 72.5945Chlorine Cl 17 12.9676 23.8136 39.61 53.4652 67.8Argon Ar 18 15.7596 27.62965 40.74 59.81 75.02Potassium K 19 4.3407 31.63 45.806 60.91 82.66Calcium Ca 20 6.1132 11.87172 50.9131 67.27 84.50Scandium Sc 21 6.5615 12.79977 24.75666 73.4894 91.65Titanium Ti 22 6.8281 13.5755 27.4917 43.2672 99.30Vanadium V 23 6.7462 14.618 29.311 46.709 65.2817Chromium Cr 24 6.7665 16.4857 30.96 49.16 69.46Manganese Mn 25 7.4340 15.6400 33.668 51.2 72.4Iron Fe 26 7.9024 16.1877 30.652 54.8 75.0Cobalt CO 27 7.8810 17.084 33.50 51.3 79.5Nickel Ni 28 7.6398 18.16884 35.19 54.9 76.06Copper Cu 29 7.7264 20.2924 36.841 57.38 79.8Zinc Zn 30 9.3942 17.96439 39.723 59.4 82.6Gallium Ga 31 5.9993 20.51514 30.71 64 87Germanium Ge 32 7.8994 15.93461 34.2241 45.7131 93.5Arsenic As 33 9.7886 18.5892 28.351 50.13 62.63Selenium Se 34 9.7524 21.19 30.8204 42.9450 68.3Bromine Br 35 11.8138 21.591 36. 47.3 59.7 Krypton Kr 36 13.9996 24.35984 36.950 52.5 64.7Rubidium Rb 37 4.1771 27.2895 40 52.6 71.0Strontium Sr 38 5.6949 11.0301 42.89 57 71.6Yttrium Y 39 6.2171 12.22 20.52 60.597 77.0Zirconium Zr 40 6.6339 13.1 22.99 34.34 80.348Niobium Nb 41 6.7589 14.0 25.04 38.3 50.55Molybdenum Mo 42 7.0924 16.16 27.13 46.4 54.49Technetium Tc 43 7.28 15.26 29.54 46 55Ruthenium Ru 44 7.3605 16.76 28.47 50 60Rhodium Rh 45 7.4589 18.08 31.06 48 65Palladium Pd 46 8.3369 19.43 32.93 53 62Silver Ag 47 7.5762 21.47746 34.83 56 68Cadmium Cd 48 8.9938 16.90831 37.48 59 72Indium In 49 5.7864 18.8703 28.03 54.4 77Tin Sn 50 7.3439 14.6322 30.50260 40.73502 72.28Antimony Sb 51 8.6084 16.63 25.3 44.2 56Tellurium Te 52 9.0096 18.6 27.96 37.41 58.75Iodine I 53 10.4513 19.1313 33 42 66Xenon Xe 54 12.1298 20.9750 32.1230 46 57Cesium Cs 55 3.8939 23.15744 35 46 62Barium Ba 56 5.2117 10.00383 35.84 49 62Lanthanum La 57 5.5769 11.059 19.1773 49.95 61.6Cerium Ce 58 5.5387 10.85 20.198 36.758 65.55Praseodymium Pr 59 5.473 10.55 21.624 38.98 57.53Neodymium Nd 60 5.5250 10.72 22.1 40.4 60.00Promethium Pm 61 5.582 10.90 22.3 41.1 61.69Samarium Sm 62 5.6436 11.07 23.4 41.4 62.66Europium Eu 63 5.6704 11.25 24.92 42.7 63.23Gadolinium Gd 64 6.1501 12.09 20.63 44.0 64.76Terbium Tb 65 5.8638 11.52 21.91 39.79 66.46Dysprosium Dy 66 5.9389 11.67 22.8 41.47 62.08Holmium Ho 67 6.0215 11.80 22.84 42.5 63.93Erbium Er 68 6.1077 11.93 22.74 42.7 65.10Thulium Tm 69 6.1843 12.05 23.68 42.7 65.42Ytterbium Yb 70 6.2542 12.176 25.05 43.56 65.58Lutetium Lu 71 5.4259 13.9 20.9594 45.25 66.8Hafnium Hf 72 6.8251 15 23.3 33.33 68.38Tantalum Ta 73 7.5496 16 22 33 45Tungsten W 74 7.8640 16.1 24 35 48Rhenium Re 75 7.8335 17 26 38 51Osmium Os 76 8.4382 17 25 40 54Iridium Ir 77 8.9670 17 27 39 57Platinum Pt 78 8.9587 18.563 28 41 55Gold Au 79 9.2255 20.20 30 44 58Mercury Hg 80 10.4375 18.7568 34.2 46 61Thallium Tl 81 6.1082 20.4283 29.83 50.7 64Lead Pb 82 7.4167 15.03248 31.9373 42.32 68.8Bismuth Bi 83 7.2856 16.703 25.56 45.3 56.0Polonium Po 84 8.417 ? 19 27 38 61Astatine At 85 9.3 20 29 41 51Radon Rn 86 10.7485 21 29 44 55Francium Fr 87 4.0727 22 33 43 59Radium Ra 88 5.2784 10.14715 34 46 58Actinium Ac 89 5.17 11.75 20 49 62Thorium Th 90 6.3067 11.9 20.0 28.8 65Protactinium Pa 91 5.89Uranium U 92 6.1941 10.6Neptunium Np 93 6.2657Plutonium Pu 94 6.0262 11.2Americium Am 95 5.9738Curium Cm 96 5.9915It looks like Neon is hotter than Argon. Argon needs 18 volts compared to 22 for Neon. I was thinking Neon was 10 volts but its actually number ten on the list. Helium is number two but needs 25 volts to ionize.
....why isnt Neon a popular weld gas? Xenon, Krypton and Radon are also Noble....
Reply:My question is answered . Thanks .
Reply:The various links given in the earlier postings seem to be broken.I have found this http://coregas.com.au/public/images/...plications.pdfHope it helpsKen
Reply:Technical college presentation (with references): "Chemical Reactions and Metal Flow in Welding" --http://eng.sut.ac.th/metal/images/st...%20welding.pdf |
