How to upload/post a picture
发表于 2021-9-1 23:11:20 | 显示全部楼层 |阅读模式
Here are the basics steps.1. Left click on Post Reply,2. Type a message or short note in the "Your Reply" area,3. Below the "Smileys" on the left going down the page you will see the area: "Attach file: to the right of that there will be a "Browse..." button, left click the button 1 time.Now you will have a file from your hard drive open up.4. Find the file/picture on your hard drive you want to post on WeldingWeb.5. Double click or left click to select the file/picture, then hit the enter key.6. You can then check your spelling or Submit your Reply.If you picture is within the parameters of WeldingWeb.com 800 x 600, your picture will be posted, if not you will get a message that your picture is too large.If you get the message that your picture is too large you will have to resize the image. You must have a software program that allows you to edit/manipulate images.
Reply:Chuck are you talking physical size in pixels, or space size in Kb?Experience is the sum of our mistakes.
Arcin' and Sparkin' Rocky D
Reply:Rocky D,Chuck said 800x600 which is picture size in pixels.  However I just checked and file size is 150kb so as long as you don't exceed that you should be fine.
Everyone luvs pics!Wes
Reply:Space in kb *153600* , 800 x 600 size limit... this helps prevent page scrolling and is pretty much standard format.  *IMO*Should be plenty... believe it or not some people have bitched cuz they could not upload their 8MB 2048 x 1536 pic they snapped off their new $900 digital camera.
Reply:is there a way to put more than one pic in a post without linking them from a website?
Reply:Let's try thispicture 1:
picture 2:
picture 3:
I did this using embedded html and using the path to my pictures on my website. Here are the html lines used to post the pictures:&ltimg src='http://www.skyweb.net/~djcvelbar/images/thumbnail/parts_etc.jpg'/&gt&ltimg src='http://www.skyweb.net/~djcvelbar/images/thumbnail/parts_bumpers.jpg'/&gt&ltimg src='http://www.skyweb.net/~djcvelbar/images/thumbnail/parts_etc.jpg'/&gtIf you couldn't tell I program for a living. I'm a real geek sometimes. I know the proper term is computer nerd, but my degree is in EE so I guess I'm a nerd and a geek!
Reply:Jadecy, ok so teach us a little html. What is the src= ? then What is skyweb.net. In other words if we wanted to type or copy the code explain how and where we would put it? Give us a lesson, DavidDavid
Reply:Originally posted by echo8287 Jadecy, ok so teach us a little html. What is the src= ? then What is skyweb.net. In other words if we wanted to type or copy the code explain how and where we would put it? Give us a lesson, David
Reply:Thanks Cutter I'll try that the next time I take some pictures for yall. DavidDavid
Reply:I use Adobe photoshop 7.0. With a Sony Syber-shot 5.0 mega pixels. I found out with camera you have to resize the pic everytime and use the vga. I just need to also learn to post several picRobert D
Reply:That's way more camera than you need to post pictures, Robert D. so You'd do yourself a favor to take the pictures using the lowest resolution.  Then crop out all unneed area & then compress it.Sure makes it easier to load for the guys on dialup.
Reply:How would I go about posting a short video?  (mpg)I do not have a personal web space to put it on.  Any ideas?
Reply:Photoshop and many other programs will also allow you to change the resolution of your photo. If you've taken the picture with a digital camera, it's a high resolution photo. When you change the image size in photoshop, there is also an option to change the resolution. set it to 72 dpi as this is the optimal resolution for a computer screen. This makes the files a lot smallerAndrew
Reply:I just wanted to be clear, this is not my work, but, I thought some folks would get a kick out of this.  There is a guy in my town that does some welding art.  Notice the use of oxygen tanks.  I have been admiring this guys work for a few years now, but I have never actually met the guy.  Small towns arent what they used to be.  I'll try to find out if he puts some of his work on-line.  If he does, I'll post the website.  Maybe one day I'll buy a good camera also, instead of borrowing a crappy one.  I should probably be more selective of my friends...they should have better equipment, right.
Smithboy...if it ain't broke, you ain't tryin'.
Reply:His name is Gordon Chandler.  He has stuff on exhibit all over.  Google him and check out his work.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Hi Chuck, I was curious, when I upload an image, is it permanently stored on the server?  The reason I ask is that there is more flexibilty in placing an html img reference in the thread body than using images as attachments.  I found that after I upload an image and viewed it, I can then copy the url of it and paste it in my thread.  I wish I could then hide the attachment - is there a way to do that?Last edited by Garauld; 12-22-2005 at 11:33 AM.- "If ya can't be handsome, ya may as well be handy!"
HTP Invertig 201Lincoln Power Mig 255CLincoln SP125+Thermal Dynamics Cutmaster 38
Reply:Do not know if the pic's came through or not. New to the show. Started building cooker. Long way to go.
Reply:this is a bench i made. i plan on making two chairs to go with it.Lincoln Power Mig 200Ready Welder spool gunLincoln Tomb Stone AC DCMPM 150 AMP DC portable Arc welder and GeneratorRiland 40 AMP Plazma Cutter
Reply:how do you post a pic that is in the thread,  VS, an attachment that opens seperatly?
Reply:To attach a picture, when you are posting/replying, click the "go advanced" option that appears below your reply box. When you scroll down, you'll see a box for "Attach files." Use that option; it's pretty self-explanatory after that.Hope that helps. If not, let me know and we'll put together a more formal documentation for you.Bob RosenbaumFormer PublisherPenton's WELDING Magazine
Reply:just a helpfully hint, Microsoft makes a picture re-sizer for windows XP that is fast and simple to use it will do hole files of pictures at one time if you want or just one at a time and you do not even need to open the picture to resize it just right click it and tell it to resize. it is a free program that was meant to be put in the released version of XP but didn't make it it so its an add on. it is free for download from Microsoft.com do a search under power toys and you will find it. almost all the new cameras out now have way too big file sizes even on the lowest resolution, heck my camera i got on sail as a discontinued model 3 years ago and its lowest res. is still too large. the XP re-sizer only works with wind.XP but is great it will even resize down to a hand held PC pic size. and it is the clearest re-sizer i have seen yet. here is one when i took it it was like 700kb now its down to 44 to put on here without any problems. i have dial up as i live out with the cow's and they don't use computers so not enough business to get high speed out here. (stupid cow's) so i suffer from slow loads of pages with big pic sizes and can not upload then aether. some of you may know me from one of the many other welding forums i frequent and i have try-ed to let every one know about this free re-sizer not only to simplify there life but to make it possible for me to enjoy there pic's as well. i stooped going to the Hobart forum for nearly 2 years because they were all the time uploading large picture sized files directly into the post not as attachments so it took me 10 minuets to just get the post to open with the pic in it i could not even read the post until the pic loaded
  attached pic's are much more user friendly to us pore slobs out in the sticks with only dial up as an option. this board seems to automatically open your pic if you only post 1 in the tread but with the smaller size requirement its still a quick load for us dial ups, and yep we still exist, beep,buup,boop,ding what a drag but its that or nothing where i live. so i would like to thank the makers of this site for limiting the file size, apologize to you broad bander's for the inconvenience, and offer the free re-sizer from Microsoft to all that would like to use it.
happy sparkin to alljamesmaking and selling great welder covers to suport my shop habbit.if you got a welder i can cover it.
  shoot me an e-mail at [email][email protected] i got time to chat.right now my e-mail with this forum is messed up so you have to e-mail me directly at the metalart address. i hope to have it resolved soon thanks James
Reply:here is a link to the re-sizer.http://www.microsoft.com/windowsxp/d...powertoys.mspxlook on the right side for the download its only 521KB's so it will download fast even for us dial up-ers.
  here is the same picture resized again down to hand held PC size. at 14.9 kb's it is still pretty good looking, not many re-sizers can pull that off most of the other programs tend to really blur up the picture when resizing. also a good thing to note is i am a long way from being a computer geek, heck I'm lucky if i can get the stupid thing to turn on, yet i can work this re-sizer with no problems and it has run trouble free for 2 or 3 years now. it is the ONLY thing i like about win.XP.so do your self a favor and try this program, even if you have a re-sizer now you should try it any way you will most likely prefer this one.one more thing of interest to note about this re-sizer. it dose not effect the original picture, it just puts in a new one sized like you asked with its size next to the file name. it will look like thisbefore resize file name = TA-185.jpgafter resize file name = TA-185.jpg and TA-185(small).jpg or in this case TA-185(WinCE).jpgits a great program well worth having.
Reply:I just cant get a file to attach,I just cant figure it out.Ive used photobucket with success,but the pics only stay posted for a couple of weeks and then vanish.Theres no such thing as scrap metal,its all good.How do you get the picture to show under your post, so that people don't have to open the attachement?  Thanks SnitzBeing "over the hill" is much better than being under it!
Reply:this is how i do it..(go to the bottom of the thread..)http://www.weldingweb.com/vbb/showthread.php?t=8076...zap!
I am not completely insane..Some parts are missing
Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
..just a test
Reply:how do i make the picute size smaller so they can be posted?
Reply:You can adjust the picture size through whatever system your computer has installed to manage photos. My computer has Microsoft Photo Editor. With a picture on the screen, I go to the "Image" pulldown menu, and click on "resize" which lets you make it smaller. I don't have any magic numbers in my head for how much smaller to make it; I just keep playing around with it until it will upload successfully.Which explains why I post so few pictures.Bob RosenbaumFormer PublisherPenton's WELDING Magazine
Reply:Testing photo insertion with this nice little project boat! (Not mine, though!)
Last edited by tanglediver; 06-22-2007 at 10:27 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Okay, since this is the "test thread" now, here goes...Check out the old pipe bender I found in my grandfather's basement..
Reply:Just checking to see if a photo will post.
Reply:testing
Reply:testmessage
Reply:Webshots, I'm thinking that is the way to go? Check my page out;http://community.webshots.com/user/m...host=communityPart of my rusty "new to me Dodge M-37 bed".
Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:My pictures weren't loading, hmmm, just testing.
Reply:Hope this shows up?
Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:trying another program....?
Reply:testing
Reply:Just testing picture download
Originally Posted by g33k
..just a test
Reply:testing
Reply:[Testing from the Shorpy site:]The Tabulator: 1917Submitted by Dave on Tue, 11/18/2008 - 2:29am.Tags: ShorpyArt Harris + Ewing Technologyimg src=http://www.shorpy.com/node/4926?size=_original1917. "Census Bureau, Department of Commerce, tabulating machine." An early punch-card tabulator, a distant forebear of today's computers. Two photos of this monster yet to come. Harris & Ewing Collection glass negative. View full size.Last edited by Oldiron2; 11-18-2008 at 09:54 PM.Reason: Trying something else; It didn't work for me.
Reply:testing upload
Reply:Test upload.Welding content: Silencer mount and intermediate pipe to silencer fabricated by myself.Rex
Reply:Man she looks like she's flyn' when she's not! Back in the day, I drove a Bonneville, but WOW.BTW Nice Content,
Reply:Test of Zip file; it doesn't work, but the individual shots from within it do.
A.CL.Comp 4.zip (27.4 KB, 56 views)Last edited by Oldiron2; 01-09-2009 at 08:56 PM.Reason: Testing
Reply:Bruce, the 'details' (or lack thereof) about the compressor are in the CL ad posted in the "What Free Stuff have you seen in your area" thread.The individual shots were 'saved'  from the CL ad, then  copied to here; they were only compressed in the Zip file. [At least I think so; I'm still 'kinda' new to this computer stuff.]In the "manage attachments" window, a zip file is shown at the bottom. This one was well within size limitations; what other 'qualifications' are there? Do firewalls/spyware programs interfere?  I seem able to right click the 'address' of the zip file (shown at the bottom of my last post here) and open in in another tab; does this work for anyone else?
GMT+8, 2025-12-19 23:51 , Processed in 0.097235 second(s), 18 queries .
