Guage vs actual measurements - LOST
发表于 2021-9-1 01:02:58 | 显示全部楼层 |阅读模式
Guys, I'm totally lost.  (nothing new there  )Is there a guide anywhere that shows guage thickness vs inch or mm thickness?  I just get too darn confused when folks say 20 guage or 16 guage cause I have no idea what that means related to inches etc.Thanks
Reply:search  wire gauge use us steel platehttp://search.netscape.com/ns/boomfr...iregauges.html
Reply:Got it, thanks Wood-n-Steel.  Greatly appreciated.
Reply:U.S. Standard Gauge Iron or Steel Sheets  Approximate Approximate Approximate Approximate  Thickness In Thickness in Weight per Weight per No. of Fractions Of Decimal Parts Square Foot Square Foot Gauge An Inch Of An Inch Iron Steel 000 3/8 .3750 15.000 lbs. 15.3000 lbs. 0 5/16 .3125 12.500 lbs. 12.7500 lbs. 3 1/4 .2500 10.000 lbs. 10.2000 lbs. 7 3/16 .1875 7.500 lbs. 7.6500 lbs. 8 11/64 .1718 6.875 lbs. 7.0125 lbs. 10 9/64 .1406 5.625 lbs. 5.7375 lbs. 12 7/64 .1093 4.375 lbs. 4.4625 lbs. 14 5/64 .0781 3.125 lbs. 3.1827 lbs. 16 1/16 .0625 2.500 lbs. 2.5500 lbs. 18 1/20 .0500 2.000 lbs. 2.0400 lbs. 20 3/80 .0375 1.500 lbs. 1.5300 lbs. 22 1/32 .0312 1.250 lbs. 1.2750 lbs. 24 1/40 .0250 1.000 lbs. 1.0200 lbs. 26 3/160 .0187 .750 lbs. .7650 lbs. 28 1/64 .0156 .625 lbs. .6375 lbs .Appreciation Gains You Recognition-
GMT+8, 2025-12-19 23:33 , Processed in 0.106590 second(s), 18 queries .
