Rosebud - regulator settings?
发表于 2021-9-1 01:02:57 | 显示全部楼层 |阅读模式
Hi all! I'm very new at gas setup and I need some help.I'm looking for some advice on setting up my Victor torch and rosebud. I've tried using 5 psi for both oxy and acetylene, but all I get is a roaring flame and as I turn up the oxy to try and get the cones to appear, the torch POPS and goes out. The rosebud is a #6. Also, my oxygen regulator guage ranges from 0 - 200. should I have a a guage with a lower range, say 0 - 50?Thanks and regards,John
Reply:4 to 1 ratio of oxygen to acet.  Basic physics requires the 4 to 1 ratio for combustion.Set your Acet @5 and your Oxygen @20 and see how it flys.  If that doesn't support the tip, jack both up and maintain the ratio.There are 2 valves on the torch handle that do all of the flame adjustment you'll need as long as the regulators are in the ballpark.  My regulators are set @ 10 and 40 for the last 40 years, and don't get adjusted.New guys tend to get way too absorbed in settings, be it regulators or amps & volts on a machine.Your gague is fine, it doesn't need to be a 50# max, and I doubt the regulator will supply 200psi.Appreciation Gains You Recognition-
Reply:if you fish around on victor's website, you will find thier literature section.http://www.thermadyne.com/vec/litera...57_65-2007.pdfFrom the chart a #6 MFA is 10/15 Oxy, 8/12 Acetylne in psi.
Reply:John.;It's real important to remenber the "the 1/7th Rule" when using a large torch. Check you acetylene bottle, and torch size. If you're using a large "Rosebud torch" with a medium or small Acetylene bottle. you can withdraw too much acetylene from the cylinder, causing Acetone to be drawn into the regulator and torch, causing SERIOUS PROBLEMS . The rule for safety is never withdraw more than 1/7th of your acetylene tank volume in an hour. Check you owners manual, or the MFG. for the volume of Acetylene your torch and tip use.
Reply:Thanks everyone! Using your suggestions (and reading the manual, as I should have done before posting here!) I got the rosebud fired up fine. I was starving the torch - I needed more fuel pressure. Regarding the 1/7th rule, my tank is about 2.5 - 3' tall and is about half the size of my Oxy tank. Wish I knew the capacity... I don't know if that's considered small - medium... My gas supplier set me up with the torch set and all my tanks.Again, thanks for the quick help. I really like this board! I will learn a lot here, and someday, perhaps, even be able to contribute!Best regards,John
GMT+8, 2025-12-19 23:34 , Processed in 0.070544 second(s), 18 queries .
