Smith Torch ?'s
发表于 2021-9-1 01:02:55 | 显示全部楼层 |阅读模式
Hi,I have an old Smith torch setup thats been in my dads basement for over 30 years. He bought it used in the 60's but never tried it.Here's whats stamped on them if you could give me an idea of the age and if they are rebuildable that would be great.Torch Body 58170 with MW 203 and MW 209 TipsCutting Torch MC 509 with a MC 1 1/2-6 TipThanksTom
Reply:That torch doesn't look all that different from one I bought a couple years back.  About all that MIGHT need rebuilding would be to replace O rings that might have dried out.That can generally be done by walking into a O ring supply house and picking up a dozen O rings for a couple bucks.  Do NOT use those POS O rings from Harbour Flotsum on a torch.Appreciation Gains You Recognition-
Reply:Should be rebuildable. We have a Smith, same vintage, different model, still get tips and parts. Things to note: the seats  for the tips are graphite rings, not O rings. They crack. DO NOT over tighten the tips, especially on the cuttting head. Just snug them. The nuts are hex-type, but DO NOT use a wrench to tighten. Only use a wrenght to loosen them if they bind. There are O rings elsewhere. The valves seem to hold up well if not gorillaed. Get flashback arrestors. Very important. Also, I would recommend getting the chart for tip-sie/pressure setting.
Reply:Here's Smith's web site, if you can't find your torch there you can contact customer service.http://www.smithequipment.com/index.htmlAppreciation Gains You Recognition-
Reply:Thanks for the infoI'll contact them Mon and see what they have to say.Tom
GMT+8, 2025-12-19 23:33 , Processed in 0.090560 second(s), 18 queries .
