Old Ge Arc Welder
发表于 2021-9-1 01:02:52 | 显示全部楼层 |阅读模式
I AQUIRED AN OLD GE WELDER NEED TO0 KNOW MORE ABOUT IT AND HOOKING IT UP  WIRE SIZE ETC.
Reply:Model? Approximate age? Style (transformer? Motor-generator?)? Pictures? How far from the panel? First place to look is the nameplate. That sould give input voltage options and corresponding current draw, which is how the wireing and breaker/fuseing will be sized. Often tells you the proper jumpering for possible hookups as well.
GMT+8, 2025-12-19 23:41 , Processed in 0.094046 second(s), 18 queries .
