Black coating on schd 40 steel pipe
发表于 2021-9-1 01:02:51 | 显示全部楼层 |阅读模式
Is this coating toxic when welded? Looks like a plastic type coating, just wonderding if it's dangerous.Anyone?
Reply:im not sure but it would be a good idea to run a grinder over the spot that you are going to weld.dawg
Reply:Grind it before welding, or it will contaminate the weld. Otherwise, no more toxic than anything else you breathe when welding.
Reply:Originally posted by enlpck Grind it before welding, or it will contaminate the weld. Otherwise, no more toxic than anything else you breathe when welding.
Reply:That may be the pipe, not the coating (the stink is a varnish and the paint used for the mill marks), or coolant, if you didn't do it dry.  We machine end preps on coupons dry, light cut on the INSIDE, and light cut on the outside. Outside for cleanliness around weld, inside for concentricity of fit. Flap wheel for cleanup at time of fit.
GMT+8, 2025-12-19 23:33 , Processed in 0.069245 second(s), 18 queries .
